Home > Forums > General Forums > Structural Mechanics
Modelling drop weight test numerically
Old   April 3, 2023, 00:33
Smile Modelling drop weight test numerically
Hassan Iftekhar
hasanifte is on a distinguished road
I require a few tips regarding matching the numerical model of drop weight test with the experimentally obtained data.
I will briefly discuss the drop weight model here. I have modeled a drop weight test on ANSYS workbench. The impact velocity is 2.653 m/s. The impact is happening on a rubber/jute epoxy composite which consists of 2 layers. The upper layer is rubber with modulus of 10 MPa. The lower layer is Jute epoxy composite. The experimental drop weight curve is already obtained. The material properties of jute epoxy composite are obtained using U20MM software. Some of the stress limits of jute composite (Tensile strength, compressive and shear strength) are obtained using literature. The jute epoxy composite and rubber is modeled as a solid plate. The current mesh is coarse. Please note rubber is not modeled using hyperelastic models to avoid complexity.
Please see the attached file to see the force vs time curve and the difference in experimental and numerical data. Blue curve is obtained numerically.
Can anyone provide a few tips in tuning the material properties/model to match the numerical data with the experimental curve.
File Type: jpg Material Properties of Jute epoxy composite.jpg (127.6 KB, 3 views)
hasanifte is offline   Reply With Quote
ansys workbench, composite, drop impact, impact force
Polydispersed phase pressure drop with drop size Laksh CFX 1 June 8, 2017 18:56
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
test cases Maciej Matyka Main CFD Forum 3 November 24, 2004 08:27
Turbulence Modelling Test Cases Adam Main CFD Forum 0 June 21, 2004 09:44
