Running Parallel on Windows using Python Scripts |
January 18, 2013, 10:44 |
The python scripts don't seem to be running as well on Windows as it is on Linux.
The first thing, I noticed when looking at the parallel_computation.py script was that it looked for an environment variable called SU2_RUN and I created an environment variable and also added the path to PATH. But now when I try to run it, it gives me the following error: C:\Program Files (x86)\Stanford ADL\SU2\Sandbox>python ../bin/parallel_computati on.py -p 12 -f config.cfg -------------------------------------------------------------------------- mpirun was unable to launch the specified application as it could not access or execute an executable: Executable: C:\Program Node: Workstation while attempting to start process rank 0. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun was unable to launch the specified application as it could not access or execute an executable: Executable: C:\Program Node: Workstation while attempting to start process rank 0. -------------------------------------------------------------------------- 12 total processes failed to start 'C:\Program' is not recognized as an internal or external command, operable program or batch file. So, it seems as though it breaks at the space between “Program Files”, so I added quotes around the run_SU2_DDC and run_SU2_CFD variables and now the error has changed to: C:\Program Files (x86)\Stanford ADL\SU2\bin>python parallel_computation.py -p 12 -f config.cfg -------------------------------------------------------------------------- mpirun was unable to launch the specified application as it could not access or execute an executable: Executable: C:\Program Files (x86)\Stanford ADL\SU2\bin\SU2_DDC config_DDC_confi g.cfg Node: Workstation while attempting to start process rank 0. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun was unable to launch the specified application as it could not access or execute an executable: Executable: C:\Program Files (x86)\Stanford ADL\SU2\bin\SU2_CFD config_CFD_confi g.cfg Node: Workstation while attempting to start process rank 0. -------------------------------------------------------------------------- 12 total processes failed to start 'C:\Program' is not recognized as an internal or external command, operable program or batch file. I did notice that the files config_DDC_config.cfg and config_CFD_config.cfg were not created. I’m not completely sure, why. It works fine on Linux, but just not on Windows. |
install, python, running, su2 |
Running mapFields with Parallel Source and Parallel Target | RDanks | OpenFOAM Pre-Processing | 4 | August 2, 2016 05:24 |
Case running in serial, but Parallel run gives error | atmcfd | OpenFOAM Running, Solving & CFD | 18 | March 26, 2016 12:40 |
parallel error with cyclic BCs for pimpleDyMFoam and trouble in resuming running | sunliming | OpenFOAM Bugs | 21 | November 22, 2013 03:38 |
Windows 7 parallel calculations | curky | SU2 Installation | 23 | May 14, 2013 02:17 |
RSH problem for parallel running in CFX | Nicola | CFX | 5 | June 18, 2012 18:31 |
