October 10, 2017, 08:05 |
Installing SU2 how ?
MM
Rep Power: 8 |
Hello Everyone
I hope you can help me I am totally new to SU2 and ubuntu I installed a virtual machine and using ubuntu I downloaded su2-5.0.0 and extracted the folder and found two another folders ( bin and Quickstart) in the quick start there is two files (inv_NACA0012.cfg and mesh_NACA0012_inv.su2 ) in the bin there are many files( like the photo attached) what shall i do next ? i read that i must use the terminal , but how ? Thanks very much for your support and concern |
October 14, 2017, 04:50 |
#2 | |
Rep Power: 9 |
In Ubuntu, you can press "ctrl + alt + t" together to open the terminal, and then use commond "cd " to get the directory that include the two files(inv_NACA0012.cfg and mesh_NACA0012_inv.su2). Then, use commond "SU2_CFD inv_NACA0012.cfg". Several minitues later, you will get the solution. |
su2, su2 install |
Installing SU2 5.0.0 with lubuntu - tecio not found | quarkz | SU2 Installation | 4 | March 1, 2017 23:01 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
Installing SU2 on Linux | tonino | SU2 Installation | 1 | August 8, 2015 16:33 |
Problem while Compiling and Installing SU2 3.2 using Cygwin | yona | SU2 Installation | 2 | July 25, 2015 10:23 |
Welcome to the Stanford University Unstructured (SU2) forum! | economon | SU2 | 0 | January 7, 2013 02:48 |
