Home > Forums > Software User Forums > SU2 > SU2 Installation
SU2 build from source on WSL (invalid syntax in mesonmain.py)
Like Tree1Likes
  • 1 Post By milowangjinhong
Old   April 26, 2023, 12:49
Default SU2 build from source on WSL (invalid syntax in mesonmain.py)
milowangjinhong is on a distinguished road
I am new to SU2 and I am trying to install and build from the source code of SU2 on WSL Ubuntu 16.04. However, I kept getting errors in the meson build process on the website. It might be something stupid but I would appreciate it if anyone could help me with it.
I firstly cloned the GitHub repo to the local directory by:
git clone https://github.com/su2code/SU2.git
then I run the meson file
./meson.py build
The code seems to be running for a while, downloading something (I assume they are prerequisites) in subprojects/ folder. Then I got this error in the following:
$ ./meson.py ./build
Checking connectivity... done.
Submodule path 'externals/mel': checked out '2484cd3258ef800a10e361016cb341834ee7930b'
ninja executable not found. Building ...
bootstrapping ninja...
warning: A compatible version of re2c (>= 0.11.3) was not found; changes to src/*.in.cc will not affect your build.
wrote build.ninja.
bootstrap complete. rebuilding...
[29/29] LINK ninja
Traceback (most recent call last):
File "./meson.py", line 83, in <module>
from mesonbuild import mesonmain
File "/mnt/c/Users/NAME/Work/Code/SU2/externals/meson/mesonbuild/mesonmain.py", line 191
mlog.error(f'Error in {script_name} helper script:')
SyntaxError: invalid syntax
I am not sure what is happening here. Could anyone please help with me? Thank you very much.
milowangjinhong is offline   Reply With Quote
Old   April 27, 2023, 06:17
Thanks guys I just figured it out. It is the python version's issue. I was using Python3.5 but meson requires at least Python 3.7. Apologies for the confusions.
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
