Home > Forums > Software User Forums > SU2 > SU2 Installation
Meson reconfigure issue with Autodiff enabled
Old   June 17, 2023, 06:47
Exclamation Meson reconfigure issue with Autodiff enabled
Vishnu_iitb
Vishnu Sankar is on a distinguished road
Hello there,
I encountered the following error when I tried enabling the autodiff feature in SU2:
ninja: Entering directory `build'
[1/4] Generating 'SU2_PY/pySU2/_pysu2ad.so.p/pySU2ad.cxx'.
FAILED: SU2_PY/pySU2/_pysu2ad.so.p/pySU2ad.cxx
/home/vishnu/swig/bin/swig -DHAVE_CGNS -DNDEBUG -DHAVE_MPI -DHAVE_METIS -DHAVE_PARMETIS -DHAVE_TECIO -DTECIOMPI -c++ -python -I/home/vishnu/anaconda3/lib/python3.8/site-packages/mpi4py/include -outdir /home/vishnu/SU2/build/SU2_PY/pySU2 -o ./SU2_PY/pySU2/_pysu2ad.so.p/pySU2ad.cxx ../SU2_PY/pySU2/pySU2ad.i
ninja: build stopped: subcommand failed.
I had no issue in setting up the directdiff feature. ninja builds it fine when only directdiff is enabled, similarly pysu2 also works fine, SU2 also works fine with mpi. I ran the Quickcase using a python script in parallel mode and it worked fine, I could also extract lift, drag and other values. But when I try enabling autodiff using meson and try to use ninja build, it fails completely and results in the error above:
Can someone comment on what's the issue here? I read somewhat similar issues in the github page (eg.: https://github.com/su2code/SU2/issues/1568 ) but my issue is slightly different I guess. Any help is much appreciated
Some additional details:
CentOS: 7.9.x
Python: 3.8.3
SU2: 7.5.1
OpenMPI: 4.1.4 & mpi4py: 3.1.4
Swig: 4.0.2
Vishnu Sankar is offline   Reply With Quote
Old   June 17, 2023, 09:05
AAA
cfdkid is on a distinguished road
What's your compiler?
cfdkid is offline   Reply With Quote
Old   June 17, 2023, 13:03
Vishnu_iitb
It's gcc 11.2.1 20220127 (Red Hat 11.2.1-9)
installation issue, pysu2ad, python wrapper
CAMWA special issue on open-source numerical solver feixu2019 OpenFOAM Announcements from Other Sources 0 October 1, 2018 11:21
CAMWA special issue on open-source numerical solver feixu2019 SU2 News & Announcements 0 October 1, 2018 11:19
[General] Building Paraview 4.1.0 with MPI and Python support reynoldsStress ParaView 10 July 27, 2017 08:38
