September 17, 2023, 08:38 |
SU2 compile error
Liming Yang
Rep Power: 2 |
When I compiled on windows according to the method of the official website, the following error appeared, may I ask where the problem is? All suggestions are helpful. Thanks a lot. |
September 24, 2023, 16:20 |
Rep Power: 3 |
Hi
Did you manage to sort out your error? I am compiling version 8.0.0 on Windows and I'm having some issues as well which are taking me time to sort out. I didn't manage to reproduce your error, so I'll summarise my case: 1. Calling Meson with --Dwith-mpi=enabled -> Meson doesn't find MPI 2. Calling Meson without mpi option -> Meson finishes, but compilation of CGNS fails: Code:
[23/754] Compiling C object externals/cgns/hdf5/H5detect.exe.p/H5detect.c.obj ninja: build stopped: subcommand failed. 4. I'm using option -Denable-tecio=false, I get a similar issue as yours but in CTecplotBinaryFileWriter.hpp: Code:
L:/prog/su2/su2_git/SU2/SU2_CFD/include/output/filewriter/CTecplotBinaryFileWriter.hpp:119:5: error: 'int64_t' does not name a type 119 | int64_t GetRankNumNodes(int which_rank) | ^~~~~~~ Code:
#include <cstdint> #include <assert.h> 5. Finally, I didn't get to compile the unit tests with -Denable-tests=true. I get a rather bizarre error message in option_structure.hpp, it looks like the compiler is getting lost somehow: Code:
[156/168] Compiling C++ object UnitTests/test_driver.exe.p/test_driver.cpp.obj FAILED: UnitTests/test_driver.exe.p/test_driver.cpp.obj "c++" "-IUnitTests/test_driver.exe.p" "-IUnitTests" "-I../UnitTests" "-ISU2_CFD/src" "-I../SU2_CFD/src" "-ICommon/src" "-I../Common/src" "-I../externals/CLI11" "-I../externals/cgns/adf" "-I../externals/cgns/adfh" "-Iexternals/cgns" "-I../externals/cgns" "-Iexternals/cgns/hdf5" "-I../externals/cgns/hdf5" "-I../externals/mel" "-I../externals/catch2" "-fdiagnostics-color=always" "-D_FILE_OFFSET_BITS=64" "-std=c++11" "-O2" "-g" "-pthread" "-fPIC" "-DHAVE_CGNS" "-DNDEBUG" -MD -MQ UnitTests/test_driver.exe.p/test_driver.cpp.obj -MF "UnitTests/test_driver.exe.p/test_driver.cpp.obj.d" -o UnitTests/test_driver.exe.p/test_driver.cpp.obj "-c" ../UnitTests/test_driver.cpp In file included from L:/prog/su2/su2_git/SU2/Common/include/basic_types/datatype_structure.hpp:34, from L:/prog/su2/su2_git/SU2/Common/include/parallelization/mpi_structure.hpp:37, from ../UnitTests/test_driver.cpp:34: L:/prog/su2/su2_git/SU2/Common/include/code_config.hpp:34: warning: "FORCEINLINE" redefined 34 | #define FORCEINLINE inline __attribute__((always_inline)) | In file included from C:/tools/msys64/mingw64/include/minwindef.h:163, from C:/tools/msys64/mingw64/include/windef.h:9, from C:/tools/msys64/mingw64/include/windows.h:69, from ../externals/catch2/catch.hpp:10066, from ../UnitTests/test_driver.cpp:32: C:/tools/msys64/mingw64/include/winnt.h:248: note: this is the location of the previous definition 248 | #define FORCEINLINE __forceinline | In file included from C:/tools/msys64/mingw64/include/windows.h:72: L:/prog/su2/su2_git/SU2/Common/include/option_structure.hpp:2098:3: error: expected identifier before numeric constant 2098 | DIFFERENCE = 1, /*!< \brief Jump given by a difference in values. */ | ^~~~~~~~~~ |
September 24, 2023, 23:10 |
Liming Yang
Rep Power: 2 |
Unfortunately, my compilation has not progressed, and I have not met your problem, so I am sorry that I cannot provide help.
I'm trying to compile the code with linux and I'm having a little trouble so far, so if you have any experience, I'd appreciate it. |
September 25, 2023, 01:43 |
bigfoot
all these errors look like they result from meson/ninja not being able to find the libraries for mpi, tecio and cgns.
First try to compile without these libraries to see if this is indeed the case: Code:
-Dwith-mpi=disabled -Denable-tecio=false -Denable-cgns=false Code:
-Dwith-mpi=enabled -Dcustom-mpi=true -Dextra-deps=mpich Last edited by bigfootedrockmidget; September 25, 2023 at 04:56. |
September 25, 2023, 03:44 |
Liming Yang
Rep Power: 2 |
Thank you very much. Once I disabled all three libraries, I was able to compile successfully.
But the libraries are downloaded from the official website, do I need additional operations? What does standard position mean? Could you explain it in more detail if necessary? Thank you very much for your help. |
September 25, 2023, 05:06 |
bigfoot
If you are working in Linux (which is the recommended professional environment) then check that you have installed the actual development package.
For instance for mpich, I have installed the packaged mpich-dev. For cgns and tecio, they are downloaded by SU2 and put in the externals/ folder. Please check that they are there. Maybe there are globally installed packages that conflict with the version that SU2 actually needs. |
September 25, 2023, 09:48 |
Liming Yang
Rep Power: 2 |
Thank you for your suggestion.
I successfully compiled in the Windows environment, after disabling the three libraries to achieve, in the Linux environment when trying to appear the problem as shown in the figure, do you know what is the reason? At your suggestion, I checked tecio and csgn, both in the externals folder downloaded. Since the file exists, where else could the problem arise? Thanks again. |
September 25, 2023, 15:57 |
bigfoot
Does it compile in linux when you switch the libraries off?
September 25, 2023, 17:30 |
#9 | |
Rep Power: 3 |
September 25, 2023, 21:23 |
Liming Yang
Rep Power: 2 |
linux builds again with the error shown in the figure
October 7, 2023, 04:21 |
#11 |
Rep Power: 3 |
Hi Liming
Those problems are sometimes hard to trace back. I managed to compile on Linux with no issues (other than some MPI settings), but I did not figure out the problem on Windows without tecio and I don't see why it should compile in first place. The fact that it does compile on Linux with the same settings suggest some dependency issues that would probably take me some time to go over. May I suggest you start over your Linux installation (I'm assuming you're using WSL2) with an English only installation. Get gcc, g++, cmake, ninja-build, swig and pkg-config from your package manager and try to compile SU2 without MPI . Sometimes Ninja gets lost with path dependencies and with WSL2 it is quite easy to start over. |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
