Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Error in optimization of the RAE2822 airfoil with the mesh in the test case
Old   March 3, 2013, 02:32
Default Error in optimization of the RAE2822 airfoil with the mesh in the test case
Tommy Chen
Tommy Chen is on a distinguished road
Hi Guys of the Stanford
I have been trying to use su2 to do a optimization case with the RAE2822 mesh in the TestCases/rans/rae2822, however the python script would run an error after the computation of the flow filed, the .cfd file and the error output is in the attachment, could you tell what is wrong with my configuration file?
Tommy Chen is offline   Reply With Quote
Old   March 5, 2013, 13:49
Thomas D. Economon
economon is on a distinguished road
Hi Tommy,
It looks like the python script is immediately trying to call SU2_CFD, rather than SU2_DDC in order to partition the mesh. Please check that you have SU2_CFD, SU2_DDC, SU2_GPC, & SU2_MDC compiled (in parallel) and available in your path.
Please see this tutorial for more details on setting up a 2-D airfoil shape optimization: http://adl.stanford.edu/docs/display...tating+Airfoil.
Cheers,
Tom
economon is offline   Reply With Quote
Old   March 5, 2013, 23:39
Tommy Chen
Originally Posted by economon View Post
Hi Tommy,
Cheers,
Tom
Dear Economon:
I have check the executable program , I am absolutely sure that the SU2_CFD, SU2_DDC, SU2_GPC, & SU2_MDC compiled (in parallel) and available in my path. however the problem is still there.
Could you try my configuration file with the mesh of TestCases/rans/rae2822 and have an optimization run on it ?
So many Thanks
Tommy
Old   March 7, 2013, 01:44
Trent Lukaczyk
rktchip is on a distinguished road
Hey Tommy,
the python options are not expecting an equals sign. could you please try using this command -
python shape_optimization.py --file turb_SA_RAE2822.cfg --partitions 14
- Trent
rktchip is offline   Reply With Quote
Old   March 8, 2013, 05:45
Tommy Chen
Originally Posted by rktchip View Post
Hey Tommy,
- Trent
Dear Trent:
I have used your recommended command, however the error is the same.it seems that the SU2_MDC was called at first , and then the SU2_CFD was called to solve the flow field, after that , when the SU2_CFD was called the second time for solving the adjoint , the process was terminated. I have check the SU2_DDC.out, it seems that the domain decomposition was successful.
Could you have a try with my configuration file and the mesh in the testcase?
Thanks
Tommy
Old   March 8, 2013, 06:03
Tommy Chen
Hey Tommy,
- Trent
I have redirect the output using the command "python shape_optimization.py --file turb_SA_RAE2822.cfg --partitions 14 >output", here are the output file and the error shown in the command line window. Together with the shape_optimization puthon script.
Old   March 8, 2013, 07:00
Tommy Chen
Hey Tommy,
- Trent
Dear Trent:
I have tried to run the optimization in serial mode, and it works OK.
It seems that there must be a tiny problem with the python script when run adjoint solver in parallel mode
Tommy
Old   March 8, 2013, 21:18
Tommy Chen
Hey Tommy,
- Trent
Dear Trent:
I have run an optimization with the TestCases/euler/naca0012, it works pretty well, however when I run on the rans mesh in TestCases/rans/RAE2822 it always crash......
By the way, the version I am using is SU2_V2.0.1 instead of V2.0, it could be some problems due to the updating of the SU2V2.0?
Tommy
Old   March 26, 2013, 10:36
Tommy Chen
Hi Tommy,
Cheers,
Tom
Hi economon
Since that the v2.0.2 has been released, I have compiled that version and have a try with the same mesh and configuration file, it still doesn't work, the problem says that :
python shape_optimization.py -f turb_SA_RAE2822.cfg -p 12 >output
Traceback (most recent call last):
File "shape_optimization.py", line 692, in <module>
acc=1e-12, iprint=2, full_output=1, epsilon=1.0e-10)
File "/home/OPTer/ProgramFiles/scipy-0.8.0/lib64/python2.6/site-packages/scipy/optimize/slsqp.py", line 282, in fmin_slsqp
fx = func(x)
File "/home/OPTer/ProgramFiles/scipy-0.8.0/lib64/python2.6/site-packages/scipy/optimize/optimize.py", line 103, in function_wrapper
return function(x, *args)
File "shape_optimization.py", line 246, in f
rename_data()
File "shape_optimization.py", line 629, in rename_data
os.rename(output_names[key][0],output_names[key][1])
OSError: [Errno 2] No such file or directory
It seems that there is sth wrong in the shape_optimization.py script.
Old   April 18, 2013, 00:59
Anant Diwakar
diwakaranant is on a distinguished road
Hi Tommy
I was trying the shape optimization case of RAE2822 airfoil using RANS
simulation. I used the configuration file posted by you.
I ran the case in serial mode, but even after 40 design cycles, the case
is not getting converged. Even the reduction in drag is negligible.
Did you encounter the same problem ?
Thanks
Anant
diwakaranant is offline   Reply With Quote
Old   April 18, 2013, 13:22
Francisco Palacios
fpalacios is on a distinguished road
Originally Posted by diwakaranant View Post
Hi Tommy
Thanks
Anant
Hi Anant,
The adjoint RANS capability is a priority for SU2 developers team. For the time being we are developing two techniques: frozen eddy viscosity, and a new technique called hybrid adjoint.
Could you please try the new release 2.0.3 using the frozen viscosity adjoint?
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   April 19, 2013, 02:32
Anant Diwakar
Thanks a lot Francisco.
I will try it with SU2 (2.0.3) version.
Regards
Anant
Old   April 19, 2013, 11:54
Tommy Chen
Regards
Anant
Hi Anant
I have tried version 2.0.3 with the mesh and configuration file I uploaded in my last thread, however it still doesn't work well.
Is that the same with yours?
Regards
Tommy
Old   April 23, 2013, 05:07
Anant Diwakar
Hi Tommy
I tried RANS optimization of RAE2822 airfoil with SU2 2.0.3, but there is an issue regarding
adjoint solver convergence. It's not working.
Were you able to run this case successfully ?
Thanks
Anant
Old   April 23, 2013, 12:26
Tommy Chen
Hi Tommy
Thanks
Anant
Hi Anant
I have the adjoint solver convergence issue , too
The iteration seems to diverge all the time, even when I switch the adj_cfl_rduction factor to be smaller.
Old   May 9, 2013, 01:14
Anant Diwakar
Hi Tommy
Were you able to run RANS shape optimization case for RAE2822 airfoil
using SU2 v 2.0.3 ?
If yes, can you share the .cfg file ?
Thanks
Anant
Old   May 13, 2013, 01:07
Tommy Chen
Hi Tommy
using SU2 v 2.0.3 ?
Thanks
Anant
Hi Anant
So sorry for my late reply.
As your question, I am able to run the RANS shape optimization case for RAE2822 airfoil using SU2 v 2.0.3 , with the modification in .cfg file as Trent proposed.
However the ajoint equation seem to diverge all the time no matter how I change the ADJ_CFL_redution factor.
Best regards
Old   May 15, 2013, 11:08
Francisco Palacios
Originally Posted by Tommy Chen View Post
Hi Anant
Best regards
Dear All,
Using the current developer version (available at the end of this week), the attached config file works perfect.
We are preparing some tutorials about RANS optimization for the next release 2.1 (mid Jul).
Thanks for using SU2,
Best,
Francisco
turb_SA_RAE2822.cfg.zip
Old   May 19, 2013, 11:22
Tommy Chen
Originally Posted by fpalacios View Post
Dear All,
Best,
Francisco
Attachment 21799
Dear Francisco
What is the current developer version (available at the end of this week) ??
Is that v2.0.3???
Old   May 20, 2013, 07:47
Anant Diwakar
Hi Francisco
Is the current developer (working RANS case) version available for download ?
Thanks
Anant
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[Other] 2D hex mesh on multi element airfoil Verfblikje OpenFOAM Meshing & Mesh Conversion 0 January 19, 2012 10:55
[snappyHexMesh] SnappyHexMesh not generate mesh first time mavimo OpenFOAM Meshing & Mesh Conversion 4 August 26, 2008 07:08
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
