Nikita Ageev
Rep Power: 9 ![]() |
I try to optimize the forebody shape. I have created my own forebody, generated mesh, performed direct and continuous adjoint solution (Euler equations). I have also checked if the onera m6 Euler optimization workable. But now I got zero gradient as a result of the SU2_DOT work. Can somebody help me with this? The working directory (without mesh and results) attached.
Tim Albring
Rep Power: 10 ![]() |
can you also attach the mesh file ? Thanks! Tim |
Nikita Ageev
Thank you, Tim!
Today I have found that scales of FFD and mesh aren't equal and FFD is "inside the model". I fixed it and hope that it will work now :-) |
Tim Albring
Alright!
Just a tip: you can visualize the FFD box after running SU2_DEF by opening the FFD_boxes.dat file within Tecplot. |
gradient, optimization, su2, zero gradient |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
[General] Problem in calculating Gradient | masaaki | ParaView | 0 | March 16, 2015 06:38 |
vortex cause pressure gradient or pressure gradient induce vortex? | fruitkiwi | Main CFD Forum | 4 | June 12, 2012 01:12 |
How to compute gradient for non-orthogonal grids? | Paul Hsieh | Main CFD Forum | 3 | November 11, 2003 04:52 |
