May 8, 2023, 06:45 |
Capabilities SU2
Theuns
Hi, new to SU2...
I'm interested in using SU2 to simulate an air and water system with heat transfer. Similar to the Fluidyne Engine shown here: https://en.wikipedia.org/wiki/Fluidy...k_fluidyne.svg https://upload.wikimedia.org/wikiped...uidyne.svg.png Is this at all possible using SU2 withour extending the software? Kind regards, |
May 9, 2023, 08:08 |
bigfoot
Rep Power: 17 |
So the air column is right on top of the water column and the water is in liquid form? So the end result is that the air-water interface will stay where it is and water and air will not mix?
The fluid-fluid interface in a multizone approach will be diffusive, so in the long term, the air and the water will become strongly mixed. We do not have an interface tracking method like VOF or a way to limit diffusion over a gas-liquid interface. You could maybe set this up in a multizone/CHT setup. You separate the 2 fluids using a thin solid wall with a high conductivity. In that way, there will not be any diffusion of species across the interface, only conduction of heat. Here is a multizone example of 2 different species: https://github.com/su2code/SU2/tree/...port/multizone |
May 9, 2023, 08:13 |
Theuns
Yes, no mixing is required to be simulated. I'll check that thanks...
dynamic fluid design, thermal conduction, water + air |
Tutorials not working | abby10 | SU2 Installation | 1 | December 28, 2021 06:35 |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 18:28 |
Introducing SU2 International Developers Society (IDS) | fpalacios | SU2 News & Announcements | 1 | June 17, 2019 22:38 |
Official release of SU2 V3.0 and SU2 Educational V1.0 | fpalacios | SU2 News & Announcements | 2 | January 22, 2014 05:28 |
Welcome to the Stanford University Unstructured (SU2) forum! | economon | SU2 | 0 | January 7, 2013 02:48 |
