May 7, 2013, 08:02 |
Creating a custom objective function
Rep Power: 13 |
Through a cursory glance at the code, I can see that objective functions go into the adjoint implementation in adjoint_solution_mean. Is that the only place where objective functions go/
I wanted to implement a custom objective function for pressure recovery for internal flows. How would I go about doing that? |
May 12, 2013, 11:04 |
#2 | |
Francisco Palacios
Rep Power: 15 |
As you know, SU2 design uses the continuous adjoint methodology, more details in: http://www.stanford.edu/~fasispg/art...-2013-0287.pdf http://adl.stanford.edu/papers/AIAA-2012-3018.pdf http://www.stanford.edu/~fasispg/art..._March2012.pdf http://www.stanford.edu/~fasispg/art...urnal_2009.pdf http://www.stanford.edu/~fasispg/art...urnal_2007.pdf A new objective function will require changes in the adjoint boundary conditions: void CAdjEulerSolution::SetForceProj_Vector(CGeometry *geometry, CSolution **solution_container, CConfig *config) and in the formula for computing the surface sensitivity. void CAdjEulerSolution::Inviscid_Sensitivity(CGeometry *geometry, CSolution **solution_container, CNumerics *solver, CConfig *config) Currently we are working on a discrete and a hybrid adjoint (it will be finished at the end of the year). Thank you for you interest in SU2, Best, Francisco |
July 3, 2013, 07:22 |
Rep Power: 13 |
I was going through some of the literature.
From what I understand, the formulation only takes surface integrals as an objective which is specified in void CAdjEulerSolution::SetForceProj_Vector(CGeometry *geometry, CSolution **solution_container, CConfig *config) Is that correct? I don't understand what I have to change in void CAdjEulerSolution::Inviscid_Sensitivity(CGeometry *geometry, CSolution **solution_container, CNumerics *solver, CConfig *config) since the only term related to the objective function is d which is coming from SetForceProj_Vector. Again, is this statement correct? For an initial attempt, I want to do an incompressible Euler optimization. Is that possible? Thank you for all the help. |
adjoint, objective function |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
Force Report help~ or maybe Custom Field Function | sailor | FLUENT | 0 | April 13, 2011 03:45 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
