Home > Forums > Software User Forums > SU2
The surface mesh is broken on 3D mesh adaptation
Old   November 21, 2013, 09:09
Default The surface mesh is broken on 3D mesh adaptation
ervasph is on a distinguished road
Dear developers,
I have run the inviscid ONERA M6 Wing case with mesh adaptation, but some error messages appear:
Number of elements to adapt: 262241
Homothetic grid adaptation
Preprocessing for doing the implicit smoothing
The surface element (0, 5051) doesn't have an associated volume element.
Then I set SMOOTH_GEOMETRY = NO and the mesh adaptation can run successfully, but I find the some surface elements are not correct. The picture of the surface adapted is attached.
thanks,
Ervas
ervasph is offline   Reply With Quote
Old   January 11, 2014, 22:40
Francisco Palacios
fpalacios is on a distinguished road
Could you please try with
% Before each computation, implicitly smooth the nodal coordinates (NO, YES)
SMOOTH_GEOMETRY= NO
% Adapt the boundary elements (NO, YES)
ADAPT_BOUNDARY= NO
Best Regards,
Francisco
fpalacios is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 18:48
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
