Home > Forums > Software User Forums > SU2
Mesh Generating Using Spring Analogy
Old   January 3, 2014, 09:56
Default Mesh Generating Using Spring Analogy
Y Yang
andromeda91 is on a distinguished road
Dear All,
I am planning to perform analysis around flapped airfoil. I have prepared mesh for unflapped airfoil. By any chance, is it possible for me to deform the airfoil geometry (mesh as well) using spring analogy method in SU2?
By doing that, I don't need to generate new mesh for the flapped airfoil.
Regards,
Yosheph Yang
andromeda91 is offline   Reply With Quote
Old   January 3, 2014, 11:33
Post
Jianming Liu
liujmljm is on a distinguished road
Originally Posted by andromeda91 View Post
Dear All,
Regards,
Yosheph Yang
In SU2, u can use FEA moving mesh method, which is more stable than spring analogy method
liujmljm is offline   Reply With Quote
Old   January 5, 2014, 14:52
Y Yang
I tried to find the FEA moving mesh method that you mentioned. However, I couldn't find it.
Can you describe to me how I am supposed to do it?
Old   January 7, 2014, 07:19
Smile
Jianming Liu
please look at the templete cfg file carefully or the source code, u will find that. good luck
Old   January 11, 2014, 21:47
Francisco Palacios
fpalacios is on a distinguished road
Yes, SU2_MDC is the right solver for grid deformation. It uses a FEA method (we have removed the spring analogy method - this method didn't work with high stretching grids - ).
There are different deformation implemented in the code. It could be useful for you to take a look at a pitching airfoil optimization problem (http://www.cfd-online.com/Forums/su2...ady-flows.html).
Best Regards,
Francisco
fpalacios is offline   Reply With Quote
Old   January 20, 2014, 08:27
Y Yang
Best Regards,
Francisco
Dear Francisco,
I have tried to look at the configuration file that you mentioned. I don't know how to modify the configuration file in here. I want to remesh the airfoil into flapped airfoil whose flap is deflected around 0.7c with around 10 degree without performing any optimization at all. If you don't mind, how should I perform this using SU2_MDC module?
Regards,
Yosheph
Old   February 12, 2014, 20:55
Thomas D. Economon
economon is on a distinguished road
Hi Yosheph,
If you can modify the locations of the surface nodes for the particular airfoil (just your flap for instance), you can input their new locations in a file to SU2_MDC and choose the option DV_KIND= SURFACE_FILE. MDC will then deform the volume mesh around the new airfoil geometry. You will also need to give the filename in the options:
% Surface deformation input filename (SURFACE_FILE DV only)
MOTION_FILENAME= mesh_motion.dat
Please see the routine CSurfaceMovement::SetSurface_Deformation(CGeometry *geometry, CConfig *config) in the file grid_movement_structure.cpp for more details on the format for the file with the new airfoil coordinates.
Cheers,
Tom
economon is offline   Reply With Quote
Old   February 26, 2014, 15:36
Tommy Chen
Tommy Chen is on a distinguished road
Originally Posted by economon View Post
Hi Yosheph,
Cheers,
Tom
Hi Tom
Actually SU2_MDC would create an initial mesh_motion file, if MOTION_FILENAME has been set and mesh_motion.dat does not exist. The related code is as:
/*--- A surface file does not exist, so write a new one for the
markers that are specified as part of the motion. ---*/
if (Surface_File.fail()) {
if (rank == MASTER_NODE)
cout << "No surface file found. Writing a new file: " << filename << "." << endl;
Surface_File.open(filename.c_str(), ios:ut);
Surface_File.precision(15);
unsigned long iMarker, jPoint, GlobalIndex, iVertex; double *Coords;
for (iMarker = 0; iMarker < config->GetnMarker_All(); iMarker++) {
if (config->GetMarker_All_DV(iMarker) == YES) {
for(iVertex = 0; iVertex < geometry->nVertex[iMarker]; iVertex++) {
jPoint = geometry->vertex[iMarker][iVertex]->GetNode();
GlobalIndex = geometry->node[jPoint]->GetGlobalIndex();
Coords = geometry->node[jPoint]->GetCoord();
Surface_File << GlobalIndex << "\t" << Coords[0] << "\t" << Coords[1];
if (nDim == 2) Surface_File << endl;
else Surface_File << "\t" << Coords[2] << endl;
However , after I test it with 3D ONERA M6 wing case in parallel mode, I found out that only the surface mesh points which owned by the master_node have been outputed. I think this is a bug somehow, I want to fix it , but do not know how.
Tommy Chen is offline   Reply With Quote
Old   October 6, 2016, 00:36
jit
jitendraseregar@gmail.com is on a distinguished road
Dear Francisco,
Regards,
Yosheph
what is the format of surface file can you please explain.
jitendraseregar@gmail.com is offline   Reply With Quote
Old   October 6, 2016, 00:40
jit
can you please explain what is the format of surface file should be. if you can give some example or simple surface file that would be a great help. thanks
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
ParaView and Qt 4.3.5 on Mac OS X 10.6 Adrian OpenFOAM 3 August 8, 2010 03:16
