Home > Forums > Software User Forums > SU2
Bump in a channel
Old   March 5, 2014, 04:33
Default Bump in a channel
Laurent Soucasse
laurent_soucasse is on a distinguished road
I am trying to run the tutorial "Bump in a channel" but changing the geometry. I would like to change the smooth bump into a half circle.
Unfortunately, I always get this error at the first iteration when running SU2
CSysSolve::modGramSchmidt: w[i+1] = NaN
terminate called after throwing an instance of 'int'
I use gmsh for creating the geometry and the mesh, I enclose the gmsh file (replace .txt by .geo). The configuration file is the one of the first tutorial "Bump in a channel".
Thanks for your help.
Laurent.
File Type: txt geo_channel.txt (744 Bytes, 37 views)
laurent_soucasse is offline   Reply With Quote
Old   March 11, 2014, 01:45
Thomas D. Economon
economon is on a distinguished road
Laurent.
Dear Laurent,
I believe that the parameters in the bump in a channel config file were optimized for max performance with that test case alone (i.e., the multigrid settings and the CFL number are fairly aggressive). First, I would recommend turning down the CFL a bit and turning multigrid off. Once you have it stable, you might try turning multigrid back on, while adjusting the number of levels for the damping to get performance.
Hope this helps,
Tom
economon is offline   Reply With Quote
Old   March 11, 2014, 08:37
Laurent Soucasse
Thanks for your answer.
I have already tried to turn the multigrid off and to strongly decrease the CFL number but the I cannot run any iteration.
Old   March 12, 2014, 10:41
Thomas D. Economon
Laurent,
Just to check that the grid is ok, can you please try setting all of the boundaries to far-field BCs and running a simulation? If the grid is ok, you should find that the residuals start around zero and that a uniform free-stream is maintained.
T
Old   March 13, 2014, 08:07
Laurent Soucasse
Originally Posted by economon View Post
Laurent,
T
There is a problem with my grid as your "farfield" test case does not work, but maybe I need a gmsh expert to understand what is going wrong.
2D flow over a Bump in channel bgraves OpenFOAM Running, Solving & CFD 6 March 23, 2017 14:41
Subsonic or transonic flow over a bump in a channel. AshwaniAssam Main CFD Forum 2 January 8, 2014 00:35
Question on the boundary condition for open channel flow, please help! ripperjack OpenFOAM Running, Solving & CFD 0 September 13, 2013 11:44
tecplot 3D velocity contours inside a channel vetnav Tecplot 4 July 14, 2010 20:03
Laminar supersonic flow past bump in channel ganesh Main CFD Forum 0 December 20, 2006 15:48
