Any way to define more than one rotating frame? |
JinZhiyi
Rep Power: 12 ![]() |
Dear developers and users:
I want to use su2 to analysis the flow around a quad-rotor uav, which have 4 rotating blades. I am wondering if it is possible to define multi-rotating centers in config file, do i need to have multi-zones in the mesh file, or any suggestions for this kind of analysis by su2. Thanks in advance Jin |
Thomas D. Economon
Rep Power: 14 ![]() |
Hi Jin,
At the moment, it is not possible to define multiple rotating reference frames. You might want to read some more information about the current capabilities in the code related to this topic in the thread here: http://www.cfd-online.com/Forums/su2...nce-model.html. I should also mention that we are starting to implement an actuator disk boundary condition in the code, and this would enable the type of simulations that you mention (modeling each of the 4 blades with a disk). Stay tuned for more info on that topic in future releases. Hope this helps, T |
Rotating mesh in a moving reference frame | mafz1g11 | FLUENT | 1 | March 23, 2019 00:13 |
UDF carbon conversion | papteo | Fluent UDF and Scheme Programming | 1 | August 18, 2011 07:32 |
how to define ogmea in planar reference frame | goshawksky | FLUENT | 0 | November 5, 2007 21:42 |
Rotating Reference frame | Ketan | FLUENT | 0 | May 25, 2007 11:58 |
Rotating Reference Frame | Ketan | FLUENT | 0 | May 17, 2007 13:13 |
