Status of the implementation of the Transition Model Gamma-Re_th |
April 14, 2014, 16:35 |
Giorgio
Dear SU2 developers,
I am interested in the transition model Gamma-Reynolds_theta coupled with SA. If I look at the relative source files (SU2_CFD/src/solver_direct_transition.cpp, SU2_CFD/src/numerics_direct_turbulent.cpp, SU2_CFD/src/numerics_direct_transition.cpp ), I see a lot of comments and print statements which indicate that this particular model is still under development. Furthermore, in the last AIAA paper about SU2, this model is not mentioned anymore. In this respect, I would like to know if you plan to continue its implementation. Thank you very much! best, g. |
April 18, 2014, 09:11 |
#2 | |
Francisco Palacios
Rep Power: 15 |
The complete implementation is in place in the branch feature_transition. Currently we are in a V&V stage. The implementation has taken some time because we started with the modification for the SA model, and then we switch to the original SST based implementation. Hopefully it will be ready in a couple of weeks, Cheers, Francisco |
April 18, 2014, 09:19 |
Giorgio
Dear Francisco,
just to be sure...you are going to implement it only for the SST model, right? Thank you very much again. Best, Giorgio |
April 18, 2014, 09:27 |
Francisco Palacios
Rep Power: 15 |
July 24, 2015, 00:04 |
Rep Power: 15 |
Hi Francisco,
Just wanted to check if you have any updates on this front - LM model implementation into SST model. Coz, when I tried adding the KIND_TRANS_MODEL = LM into either of the SA or SST cfg files for the flatplate tutorial case, a message "No LM restart yet!!" came up and I wasn't sure if I was doing anything wrong or if the implementation is still pending. Would be great to know the current status in v4.0.0. Thanks! Sree. |
September 15, 2015, 17:41 |
Thomas D. Economon
Rep Power: 14 |
We are still working on the LM model for the SST. At the moment, it still has verification/testing status, but hopefully, we will be able to put it out in a future release. It is not available in v4.0.1. Hope this helps, Tom |
April 29, 2016, 13:56 |
Transition modelling in SU2
#7 | |
Kisorthman Vimalakanthan
Rep Power: 15 |
I'm using the V4.1.1 'Cardinal' version of SU2, and I was wondering if the SST or SA transition model is available to use with this version? If not could you please give some update or any advice on transition modelling on SU2.. Thanks in advance Kind regards, Kishore Last edited by k.vimalakanthan; May 1, 2016 at 03:14. |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
turn off wall functions in Transition SST model? | johnp | FLUENT | 11 | May 26, 2020 13:57 |
Why RNGkepsilon model gives floating error | shipman | OpenFOAM Running, Solving & CFD | 3 | September 7, 2013 08:00 |
Trans. SST Intermittency Factor and Viscosity Ratio | eishinsnsayshin | FLUENT | 3 | May 23, 2012 03:02 |
Missing Information in SST Transition Model Formulation | Josh | CFX | 2 | September 14, 2010 11:49 |
