Home > Forums > Software User Forums > SU2
Limit on number of boundaries in .cfg?
Old   April 29, 2014, 17:25
Question Limit on number of boundaries in .cfg?
Nitin
neetin is on a distinguished road
Is there a limit on number of boundary faces that can be set in .cfg file? I am trying to automate geometry-mesh-analysis process. For a complex geometry, the number of faces exceed 100 (geometry automation). And these face numbers/IDs are carried through meshing to SU2. Whenever the boundary face number exceeds 100, SU2 quits with segmentation fault.
TIA.
-Neetin.
neetin is offline   Reply With Quote
Old   May 18, 2014, 21:54
Francisco Palacios
fpalacios is on a distinguished road
TIA.
-Neetin.
I see...
could you please go to option_structure.hpp and change
const unsigned int MAX_INDEX_VALUE = 100; /*!< \brief Maximum value for a marker index. */
const unsigned int MAX_NUMBER_MARKER = 200; /*!< \brief Maximum number of domains. */
by
const unsigned int MAX_INDEX_VALUE = 500; /*!< \brief Maximum value for a marker index. */
const unsigned int MAX_NUMBER_MARKER = 500; /*!< \brief Maximum number of domains. */
Thanks for using SU2,
Francisco
fpalacios is offline   Reply With Quote
Old   June 5, 2014, 08:50
Nitin
Thank you, Francisco.
Code for EARSM by Hellsten and RSM by Manceau, square duct, 2d turbulent channel Thomas Baumann OpenFOAM Running, Solving & CFD 14 October 16, 2020 04:11
Help compiling code (newbie) thsb20 OpenFOAM Programming & Development 56 August 24, 2016 04:24
decomposePar pointfield flying OpenFOAM Running, Solving & CFD 28 December 30, 2013 15:05
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
