Home > Forums > Software User Forums > SU2
Fully explicit time accurate simulation
Old   May 23, 2014, 13:14
Default Fully explicit time accurate simulation
nilesh
nilesh is on a distinguished road
I want to simulate flow over NACA 0018 using MUSCL (without slope limiter) and "explicit runge-kutta" combination (preferably RK4).
I wish to compute from t=0 to t=50 without using any kind of implicit methods. However the concept of dual time stepping is confusing to me. Dual time stepping uses euler implicit to take the problem to a steady state and then another 3 time level method to proceed to the next time step.
I am into calculating "time-accurate" solutions in which I do not use any turbulence model and explicitly compute upto an estimated non-dimensional time until the flow has fully developed. However I am unable to do so in SU2 as the config file settings confusing me. Please provide me the config file settings and solution writing settings.
Start time t=0
End time t=50
time step delt=10^-5
solution write interval: After 1000 steps.
Thanks.
nilesh is offline   Reply With Quote
Old   May 25, 2014, 08:09
nilesh
time integration=rk explicit
internal iterations=0
multigrid level=0
But the results aren't good. Drag prediction is 100 times higher.
Old   June 5, 2014, 15:20
David Manosalvas-Kjono
demanosalvas is on a distinguished road
Nilesh,
If you are interested on learning more about the details of the dual time stepping, you can take a look at "Time dependent calculations using multigrid, with applications to unsteady flows past airfoils and wings" by Prof. Antony Jameson.
With regards of the time integration schemes, there is the option to use dual time stepping, explicit euler or RK methods. All you need to do is to make sure that the method that you are planning to use is selected in your config file.
To improve the accuracy of your solution, you need to look at your mesh and make sure that it is refined in the places where you expect the highest gradients.
Hope this helps,
David
demanosalvas is offline   Reply With Quote
explicit, rk4, su2, time accurate
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
time step directories naming issue Andrea_85 OpenFOAM 3 April 3, 2014 08:38
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
