Home > Forums > Software User Forums > SU2
Pressure probes
Like Tree3Likes
  • 2 Post By sirius
  • 1 Post By Bullseye
Old   June 16, 2014, 08:42
Default Pressure probes
Sirius
sirius is on a distinguished road
What is the procedure to put pressure probes in the flow field and at the boundary in SU2? Thanks.
EMolina and chliu like this.
sirius is offline   Reply With Quote
Old   June 24, 2014, 20:19
Thomas D. Economon
economon is on a distinguished road
SU2 will output the pressure on the surface of any specified markers and then also in the volume mesh. This information is typically found in the surface_flow.dat/flow.dat or surface_flow.vtk/flow.vtk files (Tecplot/ParaView). You could, of course, add print statements to the code to output the current pressure at one of the nodes, but there is not a built in interpolation or probe function at the moment for outputting the pressure at arbitrary (x,y,z) locations. We typically do this as a post-processing step in a visualization package.
Hope this helps,
Tom
economon is offline   Reply With Quote
Old   January 25, 2016, 06:00
Bullseye is on a distinguished road
Is this function now implemented?
Haupei likes this.
Bullseye is offline   Reply With Quote
probe, probe function, probe position, probe pressure
Pressure Driven Supersonic Flow in Converging-Diverging Nozzle cdm OpenFOAM Running, Solving & CFD 7 August 28, 2019 01:37
How to get the total pressure in the UDF? zgzhai Fluent UDF and Scheme Programming 3 September 24, 2018 16:12
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
replacing of shock tube high pressure part with a boundary condition for low pressure immortality Main CFD Forum 0 May 2, 2013 13:30
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 12:41
