Home > Forums > Software User Forums > SU2
Change the python file with shape optimization
Old   July 7, 2014, 06:59
Default Change the python file with shape optimization
XingYu
454514566@qq.com is on a distinguished road
In the shape optimization,I want to make AOA set as DV,so the AOA and airfoil shape can be optimized.But the SU2 V3.2 can not handle it.
My mind is change the python file that make SU2 do it.
DO I need to change what the file is?
454514566@qq.com is offline   Reply With Quote
Old   July 19, 2014, 13:21
Francisco Palacios
fpalacios is on a distinguished road
If you want AoA as a design variable there are several options:
- use rotation with FFD boxes.
- use
% Activate fixed lift mode (specify a CL instead of AoA, NO/YES)
FIXED_CL_MODE= YES
% Target coefficient of lift for fixed lift mode (0.0 by default)
TARGET_CL= 0.1
- And obviously, it is possible to implement the AoA as a design variable (in fact SU2 already computes the derivative of AoA with respect to the design variables).
I hope this helps,
Thanks for using SU2,
Francisco
fpalacios is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 15:14
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
