Home > Forums > Software User Forums > SU2
Limiter MINMOD' problems
Old   August 7, 2014, 10:41
Default Limiter MINMOD' problems
Facundo
akun646 is on a distinguished road
Dear developers and users:
I am trying to run 2D sphere and cylinder at hypersonic regime (Mach 10 to start). When I implemented limiter in second order scheme, the only limiter that works is "VENKATAKRISHNAN". With "MINMOD" I got "Segmentation fault" as error message when the solver tries to begin.
Has anyone used limiter MINMOD in the simulations? I want to use MINMOD to compare results with another code. Thank you very much!!!
Facundo
akun646 is offline   Reply With Quote
Old   August 22, 2014, 17:41
Francisco Palacios
fpalacios is on a distinguished road
Facundo
The latest version of the code in the GitHub repository includes the bath's limiters.
Cheers,
Francisco
fpalacios is offline   Reply With Quote
Old   August 26, 2014, 08:23
Facundo
Originally Posted by fpalacios View Post
Cheers,
Francisco
Hi Francisco,
Thank you very much for your reply. After using Berth Jespersen limiter, I still got a quite big difference in the Mach number at the symmetry axis (I am using this variable for comparison) between the two code. But I don't think that difference is due to the limiter (maybe it does).
I am still doing some tests, maybe later I will post some final results to share with the community. Thanks for developing and sharing SU2.
Cheers,
Facundo
Old   August 28, 2014, 15:24
Francisco Palacios
Hi Francisco,
Cheers,
Facundo
Thanks Facundo,
My recommendation is to use
% Output residual values in the solution files
WRT_RESIDUALS= YES
% Output limiters values in the solution files
WRT_LIMITERS= YES
so you will be able to visualize residuals and limiters and detect if something goes wrong.
Cheers,
Francisco
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 03:45
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 12:13
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 11:00
