January 7, 2015, 10:41 |
Explicit RK time integration in SU2.!!!
Vino
Rep Power: 13 |
I would like to know what is the order of accuracy of the RK used in SU2. It uses three co-efficient, means three stage. If I want to make it even higher stage, say 4 stage, can I just add 4 co-efficient in config file.? or do I need to re-implement the RK in time_integration file? Also I would like to the implemented is the classical RK method, or Modified RK method (mainly for higher stability margin)? If possible, can I get the reference of the RK method implemented in SU2. Thank you. |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
Fully explicit time accurate simulation | nilesh | SU2 | 2 | June 5, 2014 15:20 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
