Home > Forums > Software User Forums > SU2
2d flutter calculation
Like Tree1Likes
  • 1 Post By hlk
Old   February 12, 2015, 02:59
Default 2d flutter calculation
varghese mathew
varghese9 is on a distinguished road
i am using 2d flutter code using the typical wing section model provided in the su2_cfd in-buit code .i am having problem to compute flutter boundary of a given airfoil. for the given mach no i am getting only one response at a particular mach no i want to plot the three responses (damping , neutral and diverging ) at a particular fixed mach no.can any body help me stating what is the parameter to be changed in the config file to obtain the diffrent response at a particular fixed mach no .
varghese9 is offline   Reply With Quote
Old   May 12, 2015, 17:25
hlk
Heather Kline
hlk is on a distinguished road
Thank you for your question
You may find some useful information regarding flutter in SU2 at the following thread:
http://www.cfd-online.com/Forums/su2...tml#post546069
For changing the Mach number, you will want to update the freestream_ values, Mach_number, and the boundary condition values for any "inlet" boundary markers. You should take a look at the config files in TestCases that most closely match your flow conditions to make sure that you are setting the correct set of conditions (for example, the Reynolds number is required in RANS calculations but not in Euler calculations, etc).
It sounds also like you may want to run a sweep of different conditions? If that is the case you may want to take a look at the python scripts in SU2_PY, which will make it easier to run a sweep of different settings.
varghese9 likes this.
hlk is offline   Reply With Quote
determining flutter index corresponding to flutter speed and flutter index variati varghese9 Main CFD Forum 2 January 29, 2015 22:38
what reason for AGARD445.6 flutter Calculation is divergence (MPCCI+FLUENT+ANSYS) franckgong Main CFD Forum 0 February 10, 2012 10:07
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 08:46
Vortex shedding and aeroelastic flutter question Freeman FLUENT 2 March 20, 2009 07:19
Warning 097- AB Siemens 6 November 15, 2004 04:41
