SU2 Rotating reference frame incompressible flow |
November 4, 2015, 05:32 |
Wouter
Rep Power: 12 |
Hey Everybody!
I am trying to use SU2 with a rotating reference frame. I have a low velocity (but large angular velocity) and therefor would like to use the incompressible solver instead of the compressible solver. However when I run SU2 incompressible with rotating reference frame it diverges directly. I noticed that the reference value to compute the forces is given as the Mach number (which you probably don't have enough information for in incompressible flow). The angular velocity goes to infinite in the start up. Does anybody know if it is possible to run SU2 in incompressible mode when using a rotating reference frame? Thank you! |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
Convergence in Rotating Reference Frame | Peter Wilkins | FLUENT | 0 | June 2, 2006 07:11 |
Rotating reference frame | hsieh | OpenFOAM Running, Solving & CFD | 2 | April 5, 2006 15:05 |
