May 2, 2016, 11:12 |
vki 3D Periodic Mesh
Dario
Rep Power: 10 |
Hello, I am working on 3D Mesh of vki Turbine. I have created the mesh in Pointwise, and when I run the SU2 code to create the periodicity , i have this problem:
Bad match for point ...... Nearest donor distance: ........ is there anyone who can help me? thank you! this is the code: % ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% % % Physical governing equations (EULER, NAVIER_STOKES, NS_PLASMA) % PHYSICAL_PROBLEM= EULER % % Mathematical problem (DIRECT, ADJOINT, LINEARIZED) MATH_PROBLEM= DIRECT % % Restart solution (NO, YES) RESTART_SOL= NO % -------------------- COMPRESSIBLE FREE-STREAM DEFINITION --------------------% % % Mach number (non-dimensional, based on the free-stream values) MACH_NUMBER= 0.01 % % Angle of attack (degrees, only for compressible flows) AoA= 0.0 % % Side-slip angle (degrees, only for compressible flows) SIDESLIP_ANGLE= 0.0 % % Free-stream pressure (101325.0 N/m^2 by default) FREESTREAM_PRESSURE= 150000.0 % % Free-stream temperature (288.15 K by default) FREESTREAM_TEMPERATURE= 288.0 % ---------------------- REFERENCE VALUE DEFINITION ---------------------------% % % Reference origin for moment computation REF_ORIGIN_MOMENT_X = 0.25 REF_ORIGIN_MOMENT_Y = 0.00 REF_ORIGIN_MOMENT_Z = 0.00 % % Reference length for pitching, rolling, and yawing non-dimensional moment REF_LENGTH_MOMENT= 1.0 % % Reference area for force coefficients (0 implies automatic calculation) REF_AREA= 1.0 % % Reference element length for computing the slope limiter epsilon REF_ELEM_LENGTH= 0.1 % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % % Euler wall boundary marker(s) (NONE = no marker) MARKER_EULER= ( pala,wall1,wall2) % % Inlet boundary marker(s) (NONE = no marker) % Format: ( inlet marker, total temperature, total pressure, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. % Default: Mach ~ 0.1 MARKER_INLET= ( ingresso, 348.0, 153960.0, 0.8667, 0.5, 0.0 ) % Comment above line and uncomment next for Mach ~ 0.7 (transonic) %MARKER_INLET= ( inlet, 316.224, 140513.23, 1.0, 0.0, 0.0 ) % % Outlet boundary marker(s) (NONE = no marker) % Format: ( outlet marker, back pressure (static), ... ) MARKER_OUTLET= ( uscita, 100000.0 ) % MARKER_PERIODIC= ( per1, per2, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.03408, 0.0 ) KIND_ADAPT= PERIODIC % MARKER_SYM= (sym,wall) % ------------------------ SURFACES IDENTIFICATION ----------------------------% % % Marker(s) of the surface to be plotted or designed MARKER_PLOTTING= ( pala ) % % Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluated MARKER_MONITORING= ( pala ) % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % % Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES) NUM_METHOD_GRAD= GREEN_GAUSS % % Courant-Friedrichs-Lewy condition of the finest grid CFL_NUMBER= 1.0 % % Adaptive CFL number (NO, YES) CFL_ADAPT= NO % % Parameters of the adaptive CFL number (factor down, factor up, CFL min value, % CFL max value ) CFL_ADAPT_PARAM= ( 1.5, 0.5, 1.0, 100.0 ) % % Runge-Kutta alpha coefficients RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 ) % % Number of total iterations EXT_ITER= 5000 % ------------------------ LINEAR SOLVER DEFINITION ---------------------------% % % Linear solver for implicit formulations (BCGSTAB, FGMRES) LINEAR_SOLVER= FGMRES % % Preconditioner of the Krylov linear solver (JACOBI, LINELET, LU_SGS) LINEAR_SOLVER_PREC= LU_SGS % % Minimum error of the linear solver for implicit formulations LINEAR_SOLVER_ERROR= 1E-4 % % Max number of iterations of the linear solver for the implicit formulation LINEAR_SOLVER_ITER= 10 % -------------------------- MULTIGRID PARAMETERS -----------------------------% % % Multi-Grid Levels (0 = no multi-grid) MGLEVEL= 0 % % Multi-grid cycle (V_CYCLE, W_CYCLE, FULLMG_CYCLE) MGCYCLE= V_CYCLE % % Multi-grid pre-smoothing level MG_PRE_SMOOTH= ( 1, 2, 3, 3 ) % % Multi-grid post-smoothing level MG_POST_SMOOTH= ( 0, 0, 0, 0 ) % % Jacobi implicit smoothing of the correction MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 ) % % Damping factor for the residual restriction MG_DAMP_RESTRICTION= 0.9 % % Damping factor for the correction prolongation MG_DAMP_PROLONGATION= 0.9 % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % % Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC, % TURKEL_PREC, MSW) CONV_NUM_METHOD_FLOW= JST % % Spatial numerical order integration (1ST_ORDER, 2ND_ORDER, 2ND_ORDER_LIMITER) % SPATIAL_ORDER_FLOW= 2ND_ORDER_LIMITER % % Slope limiter (VENKATAKRISHNAN, MINMOD) SLOPE_LIMITER_FLOW= VENKATAKRISHNAN % % Coefficient for the limiter (smooth regions) LIMITER_COEFF= 0.3 % % 1st, 2nd and 4th order artificial dissipation coefficients AD_COEFF_FLOW= ( 0.15, 0.5, 0.02 ) % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT) TIME_DISCRE_FLOW= EULER_IMPLICIT % --------------------------- CONVERGENCE PARAMETERS --------------------------% % % Convergence criteria (CAUCHY, RESIDUAL) % CONV_CRITERIA= RESIDUAL % % Residual reduction (order of magnitude with respect to the initial value) RESIDUAL_REDUCTION= 6 % % Min value of the residual (log10 of the residual) RESIDUAL_MINVAL= -12 % % Start convergence criteria at iteration number STARTCONV_ITER= 10 % % Number of elements to apply the criteria CAUCHY_ELEMS= 100 % % Epsilon to control the series convergence CAUCHY_EPS= 1E-10 % % Function to apply the criteria (LIFT, DRAG, NEARFIELD_PRESS, SENS_GEOMETRY, % SENS_MACH, DELTA_LIFT, DELTA_DRAG) CAUCHY_FUNC_FLOW= DRAG % ------------------------- INPUT/OUTPUT INFORMATION --------------------------% % % Mesh input file %MESH_FILENAME= mesh_out.su2 MESH_FILENAME= mesheuler.su2 % % Mesh input file format (SU2, CGNS, NETCDF_ASCII) MESH_FORMAT= SU2 % % Mesh output file MESH_OUT_FILENAME= mesh_euler_per.su2 % % Restart flow input file SOLUTION_FLOW_FILENAME= solution_flow.dat % % Restart linear flow input file SOLUTION_LIN_FILENAME= solution_lin.dat % % Restart adjoint input file SOLUTION_ADJ_FILENAME= solution_adj.dat % % Output file format (PARAVIEW, TECPLOT, STL) OUTPUT_FORMAT= TECPLOT % % Output file convergence history (w/o extension) CONV_FILENAME= history % % Output file restart flow RESTART_FLOW_FILENAME= solution_flow.dat % % Output file restart adjoint RESTART_ADJ_FILENAME= restart_adj.dat % % Output file linear flow RESTART_LIN_FILENAME= restart_lin.dat % % Output file flow (w/o extension) variables VOLUME_FLOW_FILENAME= flow % % Output file adjoint (w/o extension) variables VOLUME_ADJ_FILENAME= adjoint % % Output file linearized (w/o extension) variables VOLUME_LIN_FILENAME= linearized % % Output objective function gradient (using continuous adjoint) GRAD_OBJFUNC_FILENAME= of_grad.dat % % Output file surface flow coefficient (w/o extension) SURFACE_FLOW_FILENAME= surface_flow % % Output file surface adjoint coefficient (w/o extension) SURFACE_ADJ_FILENAME= surface_adjoint % % Output file surface linear coefficient (w/o extension) SURFACE_LIN_FILENAME= surface_linear % % Writing solution file frequency WRT_SOL_FREQ= 250 % % Writing convergence history frequency WRT_CON_FREQ= 1 |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
