Home > Forums > Software User Forums > SU2
Cannot convert CGNS to SU2 native mesh
Old   August 30, 2016, 23:22
Default Cannot convert CGNS to SU2 native mesh
Paul Zhang
paulzhang is on a distinguished road
Am testing the performance of SU2 by solving the DPW6 case. In the FAMILY I UNSTRUCTURED VERSIONS OF GRIDS (CGNS Files) @ http://turbmodels.larc.nasa.gov/naca...ics_grids.html, I am able to convert all of the grids of 3-7 except for the 1 and 2 grids.
The conversion process can read CGNS successfully, but it exits after outputting the total number of hexahedra,
Loading CGNS data into SU2 data structures. Three dimensional
problem. 3670016 interior elements. 7347712 grid points. 6 surface
markers. 3670016 boundary elements in index 0 (Marker =
QUAD_bdy1). 3670016 boundary elements in index 1 (Marker =
QUAD_bdy2). 1024 boundary elements in index 2 (Marker =
QUAD_bdy3). 1024 boundary elements in index 3 (Marker =
QUAD_bdy4). 2048 boundary elements in index 4 (Marker =
QUAD_bdy5). 3584 boundary elements in index 5 (Marker =
QUAD_bdy6). 3670016 hexahedra.
My guess is these two grids are too big for one processor to handle, so I tried multi-processors, but it failed as well (got Segmentation fault). The error info is
Calling ParMETIS... Finished partitioning using ParMETIS (44562
edge cuts). Communicating partition data and creating halo layers.
3692305 interior elements including halo cells. 3692305 hexahedra.
7436964 vertices including ghost points.
----------------------- Preprocessing computations ----------------------
Setting local point and element connectivity.
Setting local point and element connectivity. run: error:
cn12510: tasks 1,5,8,10,13: Segmentation fault Establishing MPI
communication patterns.
Can someone tell what is the specific reason for this failure? Is there a workaround for this?
Thanks,
Paul
paulzhang is offline   Reply With Quote
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) Combas SU2 44 March 12, 2024 00:35
[ICEM] CGNS Mesh Importation into ICEM huey1080 ANSYS Meshing & Geometry 5 April 3, 2022 18:19
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
