Home > Forums > Software User Forums > SU2
Gmsh mesh to SU2 error : "corrupted size vs. prev_size"
Old   July 29, 2017, 12:26
Exclamation Gmsh mesh to SU2 error : "corrupted size vs. prev_size"
Chris McInally
Cmac22 is on a distinguished road
Hi, I'm currently attempting to just simply run RANS solvet for a RAE2822 airfoil, meshed in gmesh. However I keep getting an error in SU2 that I don't recognize or am able to find a solution to.
Strangely SU2 seems to run fine until it comes to writing the solution file so depending on what iteration that is set to it will run up till that many iterations then exit with one of two errors, which it switches between one after the other each time I try and run it, either:
Or:
-------------------------- File Output Summary --------------------------
Writing comma-separated values (CSV) surface files.
Loading solution output data locally on each rank.
Sorting output data across all ranks.
[Chrisub:08456] *** Process received signal ***
[Chrisub:08456] Signal: Segmentation fault (11)
[Chrisub:08456] Signal code:  (128)
[Chrisub:08456] Failing at address: (nil)
[Chrisub:08456] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390)[0x7f8a6b674390]
[Chrisub:08456] [ 1] SU2_CFD[0x87bbef]
[Chrisub:08456] [ 2] SU2_CFD[0x8a1df5]
[Chrisub:08456] [ 3] SU2_CFD[0x8035f3]
[Chrisub:08456] [ 4] SU2_CFD[0x803d63]
[Chrisub:08456] [ 5] SU2_CFD[0x407c04]
[Chrisub:08456] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f8a6b2b9830]
[Chrisub:08456] [ 7] SU2_CFD[0x7d1bf9]
[Chrisub:08456] *** End of error message ***
Segmentation fault (core dumped)
I'm fairly confused and need to fix this ASAP. If anyone has any ideas that would be of great help!
Could it be to do with the splines in my gmsh file?
//Define Foil Coordinates (128pts)
Point(1)    =    {    0,        0,        0    };
Point(2)    =    {    0.0006,        0.00323,    0    };
Point(3)    =    {    0.00241,    0.00642,    0    };
Point(4)    =    {    0.00541,    0.00945,    0    };
Point(5)    =    {    0.00961,    0.01269,    0    };
Point(6)    =    {    0.01498,    0.01579,    0    };
Point(7)    =    {    0.02153,    0.01875,    0    };
Point(8)    =    {    0.02923,    0.02163,    0    };
Point(9)    =    {    0.03806,    0.02445,    0    };
Point(10)    =    {    0.04801,    0.02726,    0    };
Point(11)    =    {    0.05904,    0.03004,    0    };
Point(12)    =    {    0.07114,    0.0328,        0    };
Point(13)    =    {    0.08427,    0.03552,    0    };
Point(14)    =    {    0.0984,        0.03817,    0    };
Point(15)    =    {    0.11349,    0.04073,    0    };
Point(16)    =    {    0.12952,    0.04321,    0    };
Point(17)    =    {    0.14645,    0.04558,    0    };
Point(18)    =    {    0.16422,    0.04778,    0    };
Point(19)    =    {    0.1828,        0.04987,    0    };
Point(20)    =    {    0.20215,    0.05187,    0    };
Point(21)    =    {    0.22221,    0.05377,    0    };
Point(22)    =    {    0.24295,    0.05556,    0    };
Point(23)    =    {    0.2643,        0.05713,    0    };
Point(24)    =    {    0.28622,    0.05848,    0    };
Point(25)    =    {    0.30866,    0.05967,    0    };
Point(26)    =    {    0.33156,    0.0607,        0    };
Point(27)    =    {    0.35486,    0.06155,    0    };
Point(28)    =    {    0.37851,    0.0622,        0    };
Point(29)    =    {    0.40245,    0.06263,    0    };
Point(30)    =    {    0.42663,    0.06285,    0    };
Point(31)    =    {    0.45099,    0.06286,    0    };
Point(32)    =    {    0.47547,    0.06261,    0    };
Point(33)    =    {    0.5,        0.06212,    0    };
Point(34)    =    {    0.52453,    0.06135,    0    };
Point(35)    =    {    0.54901,    0.0603,        0    };
Point(36)    =    {    0.57336,    0.05895,    0    };
Point(37)    =    {    0.59754,    0.05733,    0    };
Point(38)    =    {    0.62149,    0.05547,    0    };
Point(39)    =    {    0.64514,    0.05339,    0    };
Point(40)    =    {    0.66845,    0.05112,    0    };
Point(41)    =    {    0.69134,    0.04857,    0    };
Point(42)    =    {    0.71378,    0.04612,    0    };
Point(43)    =    {    0.7357,        0.04338,    0    };
Point(44)    =    {    0.75705,    0.04075,    0    };
Point(45)    =    {    0.77778,    0.03795,    0    };
Point(46)    =    {    0.79785,    0.03514,    0    };
Point(47)    =    {    0.8172,        0.03231,    0    };
Point(48)    =    {    0.83578,    0.02948,    0    };
Point(49)    =    {    0.85355,    0.0267,        0    };
Point(50)    =    {    0.87048,    0.02397,    0    };
Point(51)    =    {    0.88651,    0.02131,    0    };
Point(52)    =    {    0.9016,        0.01874,    0    };
Point(53)    =    {    0.91574,    0.01627,    0    };
Point(54)    =    {    0.92886,    0.01393,    0    };
Point(55)    =    {    0.94096,    0.0117,        0    };
Point(56)    =    {    0.952,        0.00964,    0    };
Point(57)    =    {    0.96194,    0.00775,    0    };
Point(58)    =    {    0.97077,    0.00606,    0    };
Point(59)    =    {    0.97847,    0.00455,    0    };
Point(60)    =    {    0.98502,    0.00326,    0    };
Point(61)    =    {    0.99039,    0.00218,    0    };
Point(62)    =    {    0.99459,    0.00132,    0    };
Point(63)    =    {    0.99759,    0.00069,    0    };
Point(64)    =    {    0.9994,        0.0003,        0    };
Point(65)    =    {    1,        0,        0    };
Point(66)    =    {    0.9994,        -0.00001,    0    };
Point(67)    =    {    0.99759,    0.00009,    0    };
Point(68)    =    {    0.99459,    0.00026,    0    };
Point(69)    =    {    0.99039,    0.00048,    0    };
Point(70)    =    {    0.98502,    0.00071,    0    };
Point(71)    =    {    0.97847,    0.00094,    0    };
Point(72)    =    {    0.97077,    0.00113,    0    };
Point(73)    =    {    0.96194,    0.00125,    0    };
Point(74)    =    {    0.952,        0.00125,    0    };
Point(75)    =    {    0.94096,    0.00113,    0    };
Point(76)    =    {    0.92886,    0.00081,    0    };
Point(77)    =    {    0.91574,    0.00027,    0    };
Point(78)    =    {    0.9016,        -0.00049,    0    };
Point(79)    =    {    0.88651,    -0.00149,    0    };
Point(80)    =    {    0.87048,    -0.00273,    0    };
Point(81)    =    {    0.85355,    -0.00422,    0    };
Point(82)    =    {    0.83578,    -0.00594,    0    };
Point(83)    =    {    0.8172,        -0.00792,    0    };
Point(84)    =    {    0.79785,    -0.01013,    0    };
Point(85)    =    {    0.77778,    -0.01256,    0    };
Point(86)    =    {    0.75705,    -0.01524,    0    };
Point(87)    =    {    0.7357,        -0.01812,    0    };
Point(88)    =    {    0.71378,    -0.02118,    0    };
Point(89)    =    {    0.69134,    -0.02438,    0    };
Point(90)    =    {    0.66845,    -0.0277,    0    };
Point(91)    =    {    0.64514,    -0.0311,    0    };
Point(92)    =    {    0.62149,    -0.03463,    0    };
Point(93)    =    {    0.59754,    -0.03791,    0    };
Point(94)    =    {    0.57336,    -0.04127,    0    };
Point(95)    =    {    0.54901,    -0.04452,    0    };
Point(96)    =    {    0.52453,    -0.04761,    0    };
Point(97)    =    {    0.5,        -0.05044,    0    };
Point(98)    =    {    0.47547,    -0.05297,    0    };
Point(99)    =    {    0.45099,    -0.05515,    0    };
Point(100)    =    {    0.42663,    -0.05689,    0    };
Point(101)    =    {    0.40245,    -0.05817,    0    };
Point(102)    =    {    0.37851,    -0.05893,    0    };
Point(103)    =    {    0.35486,    -0.05919,    0    };
Point(104)    =    {    0.33156,    -0.059,        0    };
Point(105)    =    {    0.30866,    -0.05843,    0    };
Point(106)    =    {    0.28622,    -0.05753,    0    };
Point(107)    =    {    0.2643,        -0.05638,    0    };
Point(108)    =    {    0.24295,    -0.05498,    0    };
Point(109)    =    {    0.22221,    -0.0534,    0    };
Point(110)    =    {    0.20215,    -0.05167,    0    };
Point(111)    =    {    0.1828,        -0.04977,    0    };
Point(112)    =    {    0.16422,    -0.04775,    0    };
Point(113)    =    {    0.14645,    -0.04561,    0    };
Point(114)    =    {    0.12952,    -0.04333,    0    };
Point(115)    =    {    0.11349,    -0.04094,    0    };
Point(116)    =    {    0.0984,        -0.03844,    0    };
Point(117)    =    {    0.08427,    -0.03584,    0    };
Point(118)    =    {    0.07114,    -0.03315,    0    };
Point(119)    =    {    0.05904,    -0.03042,    0    };
Point(120)    =    {    0.04801,    -0.02761,    0    };
Point(121)    =    {    0.03806,    -0.02472,    0    };
Point(122)    =    {    0.02923,    -0.0218,    0    };
Point(123)    =    {    0.02153,    -0.0188,    0    };
Point(124)    =    {    0.01498,    -0.0158,    0    };
Point(125)    =    {    0.00961,    -0.01273,    0    };
Point(126)    =    {    0.00541,    -0.00957,    0    };
Point(127)    =    {    0.00241,    -0.00658,    0    };
Point(128)    =    {    0.0006,        -0.00317,    0    };
//Airfoil
Spline(1) = {1:128, 1};
//Circle Points
Point(130) = {0.5, 0.00183, 0};
Point(131) = {100.5, 0.00183, 0};
Point(132) = {0.5, -99.99817, 0};
Point(133) = {-99.5, 0.00183, 0};
Point(134) = {0.5, 100.00183, 0};
//farfield circle
Circle(1001) = {131, 130, 132};
Circle(1002) = {132, 130, 133};
Circle(1003) = {133, 130, 134};
Circle(1004) = {131, 130, 134};
//Surface
Line Loop(1) = {1003, -1004, 1001, 1002};     //Circle
Line Loop(2) = {1, 2};                 //airfoil
Plane Surface(1) = {1,2};
//Boundaries
Physical Line("farfield") = {1002, 1001, 1004, 1003};
Physical Line("airfoil") = {1};
//Mesh lengths
Mesh.CharacteristicLengthMax = 0.001;
Mesh.CharacteristicLengthMax = 40;
Characteristic Length {1:128} = 0.01;
I'm not concerned about the correct mesh size or boundary layers etc at the moment, just getting it to run as a coarse mesh on SU2 is the priority.
Ive attached the .su2, .cfg, and second error (as it was too many characters) file. Any help or suggestions would be greatly appreciated.
Chris
Cmac22 is offline   Reply With Quote
Old   July 31, 2017, 07:47
Tim Albring
talbring is on a distinguished road
Hi Chris
try to add also a physical volume that represents the fluid domain, that should solve the problem.
Tim
talbring is offline   Reply With Quote
Old   August 6, 2017, 20:31
Chris McInally
Originally Posted by talbring View Post
Hi Chris
Tim
Hi, how would i do this in Su2, as I'm doing a 2D problem? Do you mean to add a physical surface for fluid domain? I've tried that with same in error.
I'm able to run SU2 with the mesh made with lines instead of splines, however this leads to inaccurate results due to the sharp changes in geometry caused by straight lines instead of curves.
Old   August 7, 2017, 05:13
Alberto Pizarro
AlbertoPi is on a distinguished road
In "Line Loop(2) = {1, 2};" what is line 2?. Maybe you have to change it to "Line Loop(2) = {1};"
I tried your script in Gmsh and it doesn't seem a good mesh. Use and lower length to the elements and a Frontal algorithm to increase de quality.
For example you can add:
Mesh.Algorithm = 6; // Frontal
Characteristic Length {1:128} = 0.001;
Field[1] = Attractor;
Field[1].EdgesList = {1};
Field[1].NNodesByEdge = 5000;
Field[1].NodesList = {1:128};
Field[2] = Threshold;
Field[2].StopAtDistMax = 1;
Field[2].IField = 1;
Field[2].DistMin = 0.01;
Field[2].DistMax = 100;
Field[2].LcMax = 10;
Field[2].LcMin = 0.001;
Field[2].Sigmoid = 0;
Background Field = 2;
You have add de fluid marker as Physical Surface too. And try to run SU2 without mpirun to have more errors information.
Regards.
AlbertoPi is offline   Reply With Quote
Old   August 7, 2017, 08:41
Chris McInally
Originally Posted by AlbertoPi View Post
Regards.
Hi, thanks for the input, I've removed the extra line in the line loop, which still made no change in the error.
I'm not concerned with the mesh quality at the moment, as I've written a script that takes the output from su2 and uses it to improve the mesh in the next iterations (more detail along shock waves, high gradients etc)
The addition of the physical surface seems to not make a difference either, still same error. Does the physical surface need to be used in the SU2 cfg file? I've not seen this in any documentation?
using su2 without mpi gets the same errors as posted above
Old   August 7, 2017, 12:16
Alberto Pizarro
Hi Chris,
The quality mesh is not very important, but it shouldn't have degenerated elements.
It is not necesary to use the surface of the flow field at the config file. Could show me your config file?
Regards
Old   August 7, 2017, 12:37
Chris McInally
Hi Chris,
Regards
% ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------%
% Physical governing equations (EULER, NAVIER_STOKES,
% WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY,
% POISSON_EQUATION)
PHYSICAL_PROBLEM= EULER
% Specify turbulent model (NONE, SA, SA_NEG, SST)
KIND_TURB_MODEL= NONE
% Mathematical problem (DIRECT, CONTINUOUS_ADJOINT)
MATH_PROBLEM= DIRECT
% Restart solution (NO, YES)
RESTART_SOL= NO
% Minimize the required output memory
LOW_MEMORY_OUTPUT= NO
% -------------------- COMPRESSIBLE FREE-STREAM DEFINITION --------------------%
% Mach number (non-dimensional, based on the free-stream values)
MACH_NUMBER= 1.1
% Angle of attack (degrees, only for compressible flows)
AOA= 0
% Free-stream temperature (288.15 K by default)
FREESTREAM_TEMPERATURE= 255.556
FREESTREAM_PRESSURE= 108987.77275
% Reynolds number (non-dimensional, based on the free-stream values)
REYNOLDS_NUMBER= 6.5E6
% Reynolds length (1 m by default)
REYNOLDS_LENGTH= 1.0
% ---------------------- REFERENCE VALUE DEFINITION ---------------------------%
% Reference origin for moment computation
REF_ORIGIN_MOMENT_X = 0.25
REF_ORIGIN_MOMENT_Y = 0.00
REF_ORIGIN_MOMENT_Z = 0.00
% Reference length for pitching, rolling, and yawing non-dimensional moment
REF_LENGTH_MOMENT= 1.0
% Reference area for force coefficients (0 implies automatic calculation)
REF_AREA= 0
% Flow non-dimensionalization (DIMENSIONAL, FREESTREAM_PRESS_EQ_ONE,
% FREESTREAM_VEL_EQ_MACH, FREESTREAM_VEL_EQ_ONE)
REF_DIMENSIONALIZATION= FREESTREAM_PRESS_EQ_ONE
% -------------------- BOUNDARY CONDITION DEFINITION --------------------------%
% Navier-Stokes wall boundary marker(s) (NONE = no marker)
MARKER_EULER= ( airfoil, 0.0 )
% Farfield boundary marker(s) (NONE = no marker)
MARKER_FAR= ( farfield )
% Marker(s) of the surface to be plotted or designed
MARKER_PLOTTING= ( airfoil )
% Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluated
MARKER_MONITORING= ( airfoil )
% ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------%
% Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES)
NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES
% Courant-Friedrichs-Lewy condition of the finest grid
CFL_NUMBER= 0.75
% Max Delta time
%MAX_DELTA_TIME= 1E10
% Adaptive CFL number (NO, YES)
CFL_ADAPT= YES
% Parameters of the adaptive CFL number (factor down, factor up, CFL min value,
% CFL max value )
CFL_ADAPT_PARAM= ( 1.5, 0.5, 0.05, 1 )
% Number of total iterations
EXT_ITER= 99999
% ----------------------- SLOPE LIMITER DEFINITION ----------------------------%
% Reference element length for computing the slope and sharp edges limiters.
REF_ELEM_LENGTH= 0.01
% Coefficient for the limiter
LIMITER_COEFF= 0.1
% Freeze the value of the limiter after a number of iterations
LIMITER_ITER= 10000
% ------------------------ LINEAR SOLVER DEFINITION ---------------------------%
% Linear solver or smoother for implicit formulations (BCGSTAB, MULTIGRID, FGMRES, SMOOTHER_JACOBI,
% SMOOTHER_ILU0, SMOOTHER_LUSGS,
% SMOOTHER_LINELET)
LINEAR_SOLVER= FGMRES
% Preconditioner of the Krylov linear solver (ILU0, LU_SGS, LINELET, JACOBI)
LINEAR_SOLVER_PREC= LU_SGS
% Minimum error of the linear solver for implicit formulations
LINEAR_SOLVER_ERROR= 1E-6
% Max number of iterations of the linear solver for the implicit formulation
LINEAR_SOLVER_ITER= 5
% -------------------------- MULTIGRID PARAMETERS -----------------------------%
% Multi-Grid Levels (0 = no multi-grid)
MGLEVEL= 3
% Multi-grid cycle (V_CYCLE, W_CYCLE, FULLMG_CYCLE)
MGCYCLE= W_CYCLE
% Multigrid pre-smoothing level
MG_PRE_SMOOTH= ( 1, 2, 3, 3 )
% Multigrid post-smoothing level
MG_POST_SMOOTH= ( 0, 0, 0, 0)
% Jacobi implicit smoothing of the correction
MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0)
% Damping factor for the residual restriction
MG_DAMP_RESTRICTION= 1
% Damping factor for the correction prolongation
MG_DAMP_PROLONGATION= 1
% -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------%
% Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC,
% TURKEL_PREC, MSW)
CONV_NUM_METHOD_FLOW= JST
% Spatial numerical order integration (1ST_ORDER, 2ND_ORDER, 2ND_ORDER_LIMITER)
SPATIAL_ORDER_FLOW= 2ND_ORDER_LIMITER
% Slope limiter (VENKATAKRISHNAN, MINMOD)
SLOPE_LIMITER_FLOW= VENKATAKRISHNAN
% 1st, 2nd and 4th order artificial dissipation coefficients
AD_COEFF_FLOW= ( 0.15, 0.5, 0.02 )
% Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT)
TIME_DISCRE_FLOW= RUNGE-KUTTA_EXPLICIT
% -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------%
% Convective numerical method (SCALAR_UPWIND)
CONV_NUM_METHOD_TURB= SCALAR_UPWIND
SPATIAL_ORDER_TURB= 2ND_ORDER
SLOPE_LIMITER_TURB= VENKATAKRISHNAN
% Time discretization (EULER_IMPLICIT)
TIME_DISCRE_TURB= EULER_IMPLICIT
% Reduction factor of the CFL coefficient in the turbulence problem
CFL_REDUCTION_TURB= 1.0
% --------------------------- CONVERGENCE PARAMETERS --------------------------%
% Convergence criteria (CAUCHY, RESIDUAL)
CONV_CRITERIA= RESIDUAL
% Residual reduction (order of magnitude with respect to the initial value)
RESIDUAL_REDUCTION= 10
% Min value of the residual (log10 of the residual)
RESIDUAL_MINVAL= -8
% Start convergence criteria at iteration number
STARTCONV_ITER= 10
% Number of elements to apply the criteria
CAUCHY_ELEMS= 100
% Epsilon to control the series convergence
CAUCHY_EPS= 1E-6
% Function to apply the criteria (LIFT, DRAG, NEARFIELD_PRESS, SENS_GEOMETRY,
% SENS_MACH, DELTA_LIFT, DELTA_DRAG)
CAUCHY_FUNC_FLOW= DRAG
% ------------------------- INPUT/OUTPUT INFORMATION --------------------------%
% Mesh input file
MESH_FILENAME= RAE2822_mesh_G0.su2
% Mesh input file format (SU2, CGNS, NETCDF_ASCII)
MESH_FORMAT= SU2
% Mesh output file
MESH_OUT_FILENAME= mesh_out.su2
% Restart flow input file
SOLUTION_FLOW_FILENAME= solution_flow.dat
% Restart adjoint input file
SOLUTION_ADJ_FILENAME= solution_adj.dat
% Output file format (PARAVIEW, TECPLOT, STL)
OUTPUT_FORMAT= PARAVIEW
% Output file convergence history (w/o extension)
CONV_FILENAME= history
% Output file restart flow
RESTART_FLOW_FILENAME= solution_flow.dat
% Output file restart adjoint
RESTART_ADJ_FILENAME= restart_adj.dat
% Output file flow (w/o extension) variables
VOLUME_FLOW_FILENAME= flow
% Output file adjoint (w/o extension) variables
VOLUME_ADJ_FILENAME= adjoint
% Output objective function gradient (using continuous adjoint)
GRAD_OBJFUNC_FILENAME= of_grad.dat
% Output file surface flow coefficient (w/o extension)
SURFACE_FLOW_FILENAME= surface_flow
% Output file surface adjoint coefficient (w/o extension)
SURFACE_ADJ_FILENAME= surface_adjoint
% Writing solution file frequency
WRT_SOL_FREQ= 250
% Writing convergence history frequency
WRT_CON_FREQ= 1
Old   August 7, 2017, 12:56
Alberto Pizarro
% POISSON_EQUATION)
RESTART_SOL= NO
MACH_NUMBER= 1.1
AOA= 0
REF_AREA= 0
CFL_NUMBER= 0.75
% Max Delta time
CFL_ADAPT= YES
% CFL max value )
EXT_ITER= 99999
LIMITER_COEFF= 0.1
LIMITER_ITER= 10000
% SMOOTHER_LINELET)
MGLEVEL= 3
MGCYCLE= W_CYCLE
% TURKEL_PREC, MSW)
RESIDUAL_MINVAL= -8
STARTCONV_ITER= 10
CAUCHY_ELEMS= 100
CAUCHY_EPS= 1E-6
% Mesh input file
MESH_FORMAT= SU2
% Mesh output file
WRT_SOL_FREQ= 250
WRT_CON_FREQ= 1
I found an error in your markers:
"MARKER_EULER= ( airfoil, 0.0 )"
At Euler problems, the walls don't need heatflux, change it to MARKER_EULER= ( airfoil).
I hope it works then.
Old   August 7, 2017, 13:21
Chris McInally
Cheers, changing this doesnt make a difference, I'm still getting error:
*** Error in `SU2_CFD': corrupted size vs. prev_size: 0x00000000015edb90 ***
As I've mentioned further up I only get this problem when I use splines in gmsh, when I use straight lines SU2 runs no problems. However the straight lines aren't great for curved shapes and cause the flow to behave differently, where theres a sudden change.
Have you ever been able to use splines from gmsh in an su2 problem?
Old   August 8, 2017, 04:13
Alberto Pizarro
I never had that problem. In fact, I have tested your gmsh script and your config file with the corrections that we already commented and it works.
The error "corrupted size vs. prev_size" seems to be a python error. Are you sure that you are only running SU2_CFD in serie?
Old   August 9, 2017, 12:19
Chris McInally
Yeah i'm just running it using SU2_CFD "config" in series. Although I would need to run problems in parallel anyway as it would take far too long in series for my needs.
gmsh, rae2822, rans, su2 error
Salome cgns format mesh to SU2 JPBLourenco SU2 19 November 18, 2019 02:11
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 07:30
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
