Home > Forums > Software User Forums > SU2
Need an advice: should I simulate resin flow in fiber matrix using SU2?
Old   October 29, 2018, 03:16
Default Need an advice: should I simulate resin flow in fiber matrix using SU2?
Eugene Sharaborin
WEugene is on a distinguished road
I want to model and simulate resin flow through a fiber reinforced matrix.
In other words, flow in complex geometry: 10 tows by 10 tows and they are 10 layers. Moreover, the flow must be compressible and multiphase, because bubbles are entrapped in it. Bubbles can contain air or volatile components of resin.
Next assumptions can be considered:
  1. Flow is very slow and viscous: Ma<<1 and Re<<1
  2. Thermal-mechanical equilibrium, i.e. velocity, temperature and pressure of all components are the same in a point.
  3. gases are ideal, the resin is liquid, which depends linearly on pressure and temperature.
Thus, I need a software which:
  • use adaptive refinement mesh, bubbles are moved, and an interface must be resolved.
  • deal with very complex geometry. As it was mentioned before: 10 by 10 tows and 10 layers. There must be some concrete format to obtain from external files.
  • solver must be compressible because bubbles are entrapped in resin
And the question is next: can the code SU2 solve such complex problem. Are there any graphs: performance vs the number of proc?
WEugene is offline   Reply With Quote
bubbles, complex geometry, multiphase flows
trying to simulate two-phase jet flow with particles in surface injection ajkratos FLUENT 5 March 3, 2015 21:33
Best software to simulate scour around pier with a flow time of two weeks pedroxramos Main CFD Forum 1 October 27, 2014 16:52
How to simulate a pipe flow with a recirculating loop? Jing Main CFD Forum 0 June 25, 2014 07:40
How to simulate Choked Flow in Orifice? (URGENT) kaegen FLUENT 2 July 10, 2010 18:19
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 05:16
