Home > Forums > Software User Forums > SU2
Grid Adaptation Options
Old   February 7, 2019, 01:29
Post Grid Adaptation Options
Anjay
AlphaSierra is on a distinguished road
I'm new to SU2 and I'm trying to study shock reflections. I wanted to run grid adaptation on my mesh to improve my results. But I do not completely understand the options given in the template file. After initially running the solution for enough time, I used GRAD_FLOW but no changes were made in the adapted mesh and when I used SUPERSONIC_SHOCK, the adaptation was done at the inlet instead of near the shocks. Can someone please help me out here.
AlphaSierra is offline   Reply With Quote
Old   February 8, 2019, 22:26
Alex
AlexF is on a distinguished road
Hi Anjay,
I had run into a similar problem not long ago.
Referencing:
Inviscid Supersonic Wedge Mesh Adaptation Issue
To use the mesh adaptation codes, you must specify the following in the configuration file:
% Write binary restart files (YES, NO)
WRT_BINARY_RESTART= NO
% Read binary restart files (YES, NO)
READ_BINARY_RESTART= NO
This is because SU2’s mesh adaptation code is only compatible with ASCII files (at least when I was using it).
If you are running “python mesh_adaptation.py -f file.cfg“, the adapted mesh will be output after the solution has converged; otherwise, you must run “SU2_MSH file.cfg” with the restart file output from SU2_CFD. Also note that you can see additional options for the python script by using the “python mesh_adaptation.py -h” command.
I never used the SUPERSONIC_SHOCK option; however, the GRAD_FLOW option worked well for me. I am also fairly new to CFD so I cannot explain all of the options available, sorry. I think the GRAD_FLOW option adapts based on the density gradient, which was appropriate for my application.
Hope this helps,
Alex
AlexF is offline   Reply With Quote
Old   February 11, 2019, 00:12
Anjay
Hey Alex,
Thanks for the information. The link did help. I'm still trying to set up mesh_adaptation.py. But SU2_MSH does the job for me now. Thanks a lot.
Anjay
grid adaptation, mesh, su2_msh
Interpolation on staggered grid usirev Main CFD Forum 5 November 5, 2016 06:02
Issues with grid adaptation asonda SU2 0 August 8, 2016 12:48
Coarsening a mesh using grid adaptation Shamoon Jamshed FLUENT 3 May 2, 2012 00:26
grid adaptation L. Hamid FLUENT 1 November 14, 2011 11:33
grid partition AND dynamic mesh adaptation !!!!!!! bohis FLUENT 0 January 16, 2009 03:00
