Home > Forums > Software User Forums > SU2
Attempt to simulate compressible flow in a diffusing S-Duct
Old   May 26, 2019, 12:43
Default Attempt to simulate compressible flow in a diffusing S-Duct
Alex Landsberg
landsber is on a distinguished road
Hello, respected community.
I am trying to simulate with SU2 the compressible flow in a S-Duct (test case of S-Duct of Wellborn - see paper by Harloff et al. in https://ntrs.nasa.gov/archive/nasa/c...9920024502.pdf ).
I assign boundary conditions as follows:
1) inlet (entry to S-Duct):
INLET_TYPE= TOTAL_CONDITIONS
MARKER_INLET= ( inlet marker, total temp, total pressure,
flow_direction_x, flow_direction_y, flow_direction_z )
2) outlet (exit from S-Duct)
MARKER_OUTLET= ( outlet marker, back pressure (static) )
3) Inner wall of S-Duct - Navier-Stokes adiabatic wall boundary
MARKER_HEATFLUX= ( inner_wall_marker, 0.0 )
Numerical method - ROE scheme, limiter of Venkatakrishnan = 0.5, CFL = 0.5.
As a result, the calculation does not converge and
the condition of mass flow conservation is not satisfied between the entry and exit planes.
In addition, at some iteration number, the solver gives a warning:
"There are XXX non-physical points in the solution".
In case of use Euler wall boundary, the calculation converges and
the condition of mass flow conservation is achieved.
Maybe someone faced a similar situation - Does anybody have some ideas why the RANS Spalart-Allmaras SU2 diverges for such a standard tes-case for internal flow ?
Any help will be kindly appreciate since currently we are unable to resolve that issue.
Sincerely yours,
Alexander
landsber is offline   Reply With Quote
Old   May 30, 2019, 19:20
Nitish Anand
nitish_anand is on a distinguished road
Hey Alexander,
I usually ramp the back-pressure for supersonic turbomachinery cases, maybe you can try that out.
Thanks,
Nitish
nitish_anand is offline   Reply With Quote
back pressure, boundary conditions, inlet and outlet, internal flow
analyzing the temperature of fliud (air) flow inside an underground duct. arshbunny CFX 9 April 3, 2014 08:52
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
urgent help needed with 2d compressible flow James FLUENT 2 June 20, 2007 04:22
how to simulate compressible swirling flow? ravi FLUENT 2 May 22, 2007 08:36
Compressible duct flow Masoud Main CFD Forum 0 December 20, 2005 13:38
