Home > Forums > Software User Forums > SU2
Convergence of supercritical airfoil 2D simulation
Old   May 28, 2019, 03:55
Default Convergence of supercritical airfoil 2D simulation
Eric Claro Dittrich
ericclaro is on a distinguished road
Hello there,
I am trying to simulate the flow over the supercritical airfoil OAT15A. I have defined a 2D c-grid around it and want to use RANS equations to solve it. So far I have used the SA turbulence model since it yielded the best results. Other settings were taken from RANS simulations I did on su2 that yielded good results.
I am having some trouble converging the simulation. The lowest my Rho residual gets is around -4.5, indeed insufficient. It does not go lower than this and at some point it diverges. I am attaching the cfg file with the simulation configuration that gave the best convergence I got.
I attempted to simulate it using a fine and coarse grid, but both did not converge well enough. I am posting some pictures of the grid as well as of the domain (which in my opinion seems large enough). Boundary layer is discretised with first elements with 5e-6 m height (which in my experience yield decent y+ values).
Please let me know if you have any ideas to improve the convergence of the simulation!
ericclaro is offline   Reply With Quote
Old   May 28, 2019, 17:03
Amit
aero_amit is on a distinguished road
Few suggestions -
1- Your CFL value is on higher side to start with, use lower CFL value initially and later use higher value.
2- You can also see if switching off multi grid helps.
3- Give a try to other upwind schemes.
4- Use latest version SU2-6.2.0
aero_amit is offline   Reply With Quote
Old   May 28, 2019, 17:20
Eric Claro Dittrich
Hello, thanks a lot for your help, I will try to implement these changes.
I also thought about starting with an upwind scheme, butI am quite new to su2 and couldn't find a suitable option. I tried once to use SCALAR_UPWIND, but apparently this method is only defined for turbulence computations, the software did not allow me to use it at CONV_NUM_METHOD_FLOW.
Any recommendations?
Old   May 29, 2019, 13:02
Amit
Actually SCALAR UPWIND you have mentioned is Convective numerical method (CONV_NUM_METHOD_TURB) for turbulent flow.
I was talking about CONV_NUM_METHOD_FLOW.
Try ROE, HLLC, AUSMPLUSUP OR SLAU2 for this Mach number.
Old   January 17, 2024, 14:28
___cony7___ is on a distinguished road
Could you please share the mesh file for this airfoil?
___cony7___ is offline   Reply With Quote
Need help for the 2D airfoil simulation using OpenFoam losiola OpenFOAM Running, Solving & CFD 0 October 10, 2018 10:22
Convergence Problem - Transient Simulation gemxx Main CFD Forum 0 July 15, 2018 09:36
Airfoil 2D cfd simulation Cocorito90 OpenFOAM Running, Solving & CFD 14 December 19, 2016 03:43
Simulation of DU 97 W 300 2D Airfoil daniele.arloti FLUENT 0 December 2, 2015 06:25
Compressible transonic airfoil RAE2822 simulation Stefano Siemens 9 June 21, 2006 10:47
