Poor quality of mesh after deformation (SU2-5.0.0) |
March 11, 2017, 01:21 |
WANG,Hao
Rep Power: 9 |
I used SU2_DEF to evaluate CRM wing grid deformation, but the quality of my structured mesh is pretty bad. My question is whether the FFD box settings could affect the grid deformation,for example the distance of FFD box from the wall. Another question is whether the strctured mesh doesn't fit SU2_DEF?
Could anyone help with this ? thank you! Here are my FFD boxes, configuration file and slice of my wing (red color is deformed grid, the black one is original grid) |
March 11, 2017, 03:54 |
#2 | |
Heather Kline
Rep Power: 13 |
There are some deformation settings that can be altered to get a smoother deformation, see the GRID DEFORMATION PARAMETERS section of the config_template.cfg file provided with the code. You may also want to check whether the FFD box boundary intersects the geometry at any point (which would freeze a plane of the box). |
March 11, 2017, 07:30 |
#3 | |
WANG,Hao
Rep Power: 9 |
March 14, 2017, 15:47 |
#4 | |
Heather Kline
Rep Power: 13 |
The grid deformation method uses the spring analogy, which does mean that shapes that would be unstable in a physical structure (ie, a square vs a triangle) suffer from the same problems in the mesh deformation. One thing to try is using the stiffness parameters, ie using wall distance which will better preserve the shape of the mesh near the wall, or increasing the constant stiffness (with DEFORM_ELASTICITY_MODULUS, which defaults to 2E11) |
March 17, 2017, 04:10 |
#5 | |
WANG,Hao
Rep Power: 9 |
Thank you again |
July 5, 2019, 09:48 |
prisms vs tets
#6 | |
Vishnu KV
Rep Power: 7 |
ffd, grid deformation |
Update of the variables after dynamic mesh motion. | gtg258f | OpenFOAM Programming & Development | 9 | January 18, 2014 10:08 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
overflow and negative volume error in mesh deformation | sakalido | CFX | 11 | November 27, 2012 15:16 |
A question on adaptive remeshing or mesh deformation for handling object motions | daveatstyacht | OpenFOAM | 10 | November 13, 2010 09:29 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
