pitching motion (not sinusoidal) of grid movement |
December 27, 2019, 05:44 |
yonghong
Rep Power: 7 |
Hi.
I am unsteady simulation of an airfoil with a flap having pitching motions. Instead of the default sinusoidal motion, I defined the motion in the corresponding module in the file of 'grid_movement_structure.cpp' as dpsi = -Ampl[2]*(abs(sin(Omega[2]*time_new + Phase[2])) - abs(sin(Omega[2]*time_old + Phase[2]))); After I got the results, I viewed the animation of the simulation. The mesh deformation history was correct, but the lift coefficient history is a little bit strange. I wonder after I modified the 'grid_movement_structure.cpp', is there anywhere that I also should modify too. Many thanks Kevin |
airfoil pitching motion case | liulangdefeng2222 | FLUENT | 0 | June 12, 2017 02:10 |
[Other] Induced Motion on Pitching Plate | danib1802 | OpenFOAM Meshing & Mesh Conversion | 0 | April 21, 2017 10:19 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 04:27 |
External management of solid motion (using dynamicmesh) | maxou1993 | Main CFD Forum | 0 | July 28, 2015 11:37 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 11:18 |
