How to get the Screen output of SU2 run from terminal into a csv file? |
Vatsa
Rep Power: 0 ![]() |
I'm running RANS simulations of golf ball and i would like to plot Drag coefficient vs number of iterations of which the values are being displayed in terminal while running a simulation. What settings are needed to be changed in config.cfg file in order to get the data output. Thank you Last edited by vatsa_6; April 30, 2020 at 17:18. Reason: Spelling |
Akshay Koodly
Rep Power: 8 ![]() |
There is a history file written when you run your simulations. You can check the history output section here (https://su2code.github.io/docs_v7/Custom-Output/) to customize your outputs. Specifically to plot Cd vs iteration you can try HISTORY_OUTPUT = (ITER, RMS_RES, AERO_COEFF) Cheers. |
data extract, su2 |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
