Home > Forums > Software User Forums > SU2
SU2 Real Gas Lookup Tables or 3D Polynomials
Old   June 1, 2020, 11:39
Default SU2 Real Gas Lookup Tables or 3D Polynomials
David Stevens
dwstevens is on a distinguished road
Good Morning,
I am working on building some SCO2 models at conditions that will not be suitable for a the Peng-Robinson EOS (closer to the critical point). Also the conditions will not be well suited for constant transport properties or Sutherland's rule for viscosity.
I have come across numerous mentions in papers, presentations, and git posts of SU2 working on implementing a plugin for FluidProp to model real gas thermo and transport properties near the critical point. I am curious on development status of this feature. Will it be beta soon etc...?
I was also wondering if it would be possible to define 3D polynomial equations f(T,P) for rho, mu, gamma, etc...? I know su2 supports 2D polynomials for properties under certain conditions.
Links to FluidProp plugin mentions are bellow.
Thank you,
David Stevens
Staff Engineer
Peregrine Turbine Technologies LLC
https://su2code.github.io/documents/...2_dev_gori.pdf
https://su2code.github.io/documents/...821_012013.pdf
https://github.com/su2code/SU2/issues/794
https://www.sciencedirect.com/scienc...77750318305891
dwstevens is offline   Reply With Quote
Old   June 2, 2020, 14:16
bernulli is on a distinguished road
I am stuck at a similar point. I was looking into SU2 for a non-ideal thermodynamics solver based on the article "SU2: the Open-Source Software for Non-ideal Compressible Flows", however, I'm a bit stuck for heat transfer at supercritical conditions now.
The often-mentioned tables are a commercial product you can buy from www.asimptote.com , but they are only integrated for SU2 v.4 (which is four years old) and you need to specify fluids and thermodynamic regions.
Using the built-in model of non-ideal compressible fluids restricts you to constant thermal conductivity, viscosity, and ratio of specific heats, which really limits the applicability when what you are interested in are non-ideal fluids with non-ideal properties.
Clearly I am doing something wrong!
Daniel
Last edited by bernulli; June 2, 2020 at 15:01. Reason: toned it down, I am glad people develop SU2
bernulli is offline   Reply With Quote
eos, properties, real gas, tables
make a new data from external .txt data and save it in a UDM etedalgara Fluent UDF and Scheme Programming 27 February 26, 2020 03:15
error C2063: 'PMV' : not a function Ahmed Hassan Fluent UDF and Scheme Programming 6 February 7, 2019 08:26
Boundary condition temerature profile ahvz Fluent UDF and Scheme Programming 6 February 16, 2014 10:24
Ideal gas v.s. Real gas for wing simulation Anna Tian Main CFD Forum 1 December 16, 2013 11:39
help me check udf tranvantrung551987 Fluent UDF and Scheme Programming 0 August 23, 2013 05:55
