Home > Forums > Software User Forums > SU2
SU2 inlet profile error
Old   June 8, 2020, 11:42
Default SU2 inlet profile error
David Stevens
dwstevens is on a distinguished road
I have working with a velocity inlet profile fro a 3D case and have run into what seems to be an error in the profile feature of or SU2 or possibly the cgns mesh reader.
My inlet profile is an annulus with a structured hex mesh in cgns format output by ANSYS. I generate the inlet profile .dat file using a python script. when I attempt to use the file in SU2 I get errors regarding the node matching tolerance even though I know my profile nodes and mesh nodes match extremely well (checked in paraview). As my next trouble shooting step I forced SU2 to generate the inlet profile template by not including the profile .dat file. I plotted the generated points and the mesh in Paraview and the results were quite astounding (see below).
At this point I suspect one of the following:
a.) The inlet profile function in SU2 has an error that does not correctly match profile points to mesh nodes.
b.) SU2 is not reading the .cgns mesh file correctly and thus cannot match the points.
I have attached an image of a portion of the the inlet surface mesh with the inlet profile template points generated by SU2 (profile points are red).
dwstevens is offline   Reply With Quote
Old   June 8, 2020, 16:08
Default tIPS
shams
shamsmehra90 is on a distinguished road
Hi, we need solution for this error
shamsmehra90 is offline   Reply With Quote
cgns file read, profile boundary
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 06:25
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
