Home > Forums > Software User Forums > SU2
Unsteady simulation from SU2 tutorial
Old   January 25, 2021, 09:43
Default Unsteady simulation from SU2 tutorial
William Haigh
WilliamH is on a distinguished road
Hi everyone,
I want to run an unsteady simulation on an aerofoil but I having troubles. To practice, I have tried to run the example given 'Unsteady NACA0012' on the SU2 website. It runs fine and converges but I would like to understand how to visualise the results. I changed the output format to ParaView. The code outputs 32 vtk files corresponding to each iteration. However, I want to see how the flow and airfoil change with respect to time. I can't seem to do that when I open one of the vtk files.
Does anyone have any advice on how to solve this issue? Basically, I want to be able to press the play button in ParaView and see the flow change around the airfoil.
Thanks
William
WilliamH is offline   Reply With Quote
Old   January 25, 2021, 13:27
pcg
Pedro Gomes
pcg is on a distinguished road
When you do file open in Paraview and browse to those files Paraview it should show them with just one name something with ... at the end (and if you expand that you see the 32 files).
Select the name with ... and not one of the individual files.
pcg is offline   Reply With Quote
Old   January 26, 2021, 03:48
William Haigh
Thank you very much for your help!
paraview, tutorial case, unsteady
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 05:53
unsteady simulation with BC transition model in su2 windywestlife SU2 0 April 20, 2019 00:16
Unsteady simulation of rotating duct SRF or Sliding mesh Alisa_W FLUENT 7 January 22, 2019 06:34
The initialization of flow field for time accurate, unsteady simulation and BC zhengjg SU2 3 September 29, 2017 15:38
Unsteady simulation of flow past wheel Tom FLUENT 8 January 18, 2006 10:54
