Home > Forums > Software User Forums > SU2
SU2 Min and Max coodinates
Old   February 21, 2021, 10:55
Default SU2 Min and Max coodinates
yashb97 is on a distinguished road
I am trying to solve for a flow in a converging nozzle, but I keep getting an error stating: FGMRES orthogonalization failed, linear solver diverged.
I have also noticed after analysing the output from SU2 that it has detected the following:
Wetted area = 0 m.
Area projection in the x-plane = 0 m, y-plane = 0 m.
Max. coordinate in the x-direction = -1e+010 m, y-direction = -1e+010 m.
Min. coordinate in the x-direction = 1e+010 m, y-direction = 1e+010 m.
The detected minimum and maximum coordinates are not consistent with the actual values. Also the area values are 0. I have tried using the same mesh (different format) on Fluent and it runs fine. I am only getting the diverging problem on SU2. Any ideas?
yashb97 is offline   Reply With Quote
Old   February 21, 2021, 17:11
pcg
Pedro Gomes
pcg is on a distinguished road
Assuming you are exporting the grid in CGNS format, change the CGNS options (ADF / HDF) I am not sure which one we support, but there are not that many options.
pcg is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
Converging Diverging Nozzle with dbnsTurbFoam Saleh Abuhanieh OpenFOAM Running, Solving & CFD 4 December 13, 2019 10:26
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
