August 16, 2021, 14:45 |
Issue with Discrete Adjoint solver
#1 | |
Hareshram
Hello, I'm trying perform 3D shape optimization of an underwater flow around a turbine.
The Direct problem is run using INC_RANS solver in a rotational frame and converges to an order of 1e-10. I created an FFD box around one of the blades and use SU2_CFD_AD to perform the DISCRETE_ADJOINT calculation from the converged solution. The code however fails to start and gives the error, "Killed". I have attached the cfg file as well. I'm not sure what this error means. Any help will be appreciated. Thanks. Quote:
August 17, 2021, 07:02 |
Pedro Gomes
You are probably running out of ram. The discrete adjoint can use up to 10 times more than the primal.
If you are using multigrid turn it off for the adjoint. |
August 17, 2021, 13:55 |
Hareshram
Thanks! That was my issue.
June 21, 2022, 03:23 |
Kaan
Rep Power: 8 |
For my experiences, I got this error because memory is not sufficient for discrete adjoint solver.
New obj func in discrete adjoint solver | Zhen ZHANG | SU2 | 1 | August 1, 2021 23:17 |
Questions regarding Discrete Adjoint Solver | Daaman | SU2 | 1 | April 24, 2021 05:25 |
Discrete adjoint for multi-zone problems | pgdelaserna | SU2 | 0 | September 18, 2019 04:44 |
Fluent Adjoint Solver? | ex10148 | FLUENT | 16 | September 28, 2018 08:11 |
Radiation Modeling Using Discrete Ordinates Method and Parallel Solver | malicemethods | FLUENT | 3 | May 25, 2018 14:25 |
