Home > Forums > Software User Forums > SU2
Continuous_adjoint does not converge if mesh change
Prev Previous Post   Next Post Next
Old   December 3, 2021, 13:31
Default Continuous_adjoint does not converge if mesh change
Andrea Michelotti
AndreaMichelotti is on a distinguished road
Hello everyone,
I am running a CONTINUOUS_ADJOINT problem with two slightly different meshes for the same airfoil.
The main difference in those files is the refinement around the airfoil.
In the first one, the size of the cells which distance is 1 m from the profile is 0.05 m, in the other one the size is 0.03 m for a distance of 0.5 m.
In the first case the adjoint solution is reached in less than 50 iteration, in the other one the solution is not found.
I upload the .cfg file and the meshes at this link:
https://drive.google.com/file/d/1m9i...ew?usp=sharing
Does anyone know why does it happen?
AndreaMichelotti is offline   Reply With Quote
continuous_adjoint, mesh, problem
Why my results change when I use a finer mesh? amirhossein taghizadeh Main CFD Forum 6 November 20, 2021 00:37
Diffusive flux in porous structure doesn't converge with smaller mesh Adam_K OpenFOAM Running, Solving & CFD 0 May 21, 2021 02:53
[snappyHexMesh] snappyHexMesh stuck when snap is turned on yukuns OpenFOAM Meshing & Mesh Conversion 3 February 2, 2021 13:05
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
