January 24, 2022, 07:46 |
Fluid model in SU2
Shahid Khan
Rep Power: 4 |
In case of fluid model multple options are present. By default it takes FLUID_MODEL= STANDARD_AIR with GAMMA and GAS_CONSTANT parameter values provided.
If I want to use IDEAL_GAS instead of STANDARD_AIR, what all parameters do I need to define (like gamma etc) and what is the main difference between the two? |
January 25, 2022, 04:42 |
PENG YAN
Rep Power: 4 |
Assuming you use same fluid, e.g., Nitrogen (N2), then its gamma and gas constant should be same, regardless you choose standard air or ideal air.
For ideal gas, we compute density based on P=RT/v calculation. For standard air, we obtain density based on experiment data. Hope this helps. |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 21:16 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
