How to change the angle of attack by rotating the airfoil? |
January 24, 2023, 16:14 |
Rep Power: 3 |
I am running an unsteady C-grid simulation for an airfoil with a uniform farfield (INC_NAVIER_STOKES solver). Is there any option in SU2 to rotate the airfoil to a certain angle? Something similar to a moving grid where there is an inner zone of the grid that moves and the rest doesn't move? I would like to use the same mesh for an airfoil and run it for several angles of attack. Changing the angle of attack won't be useful because I have a C grid with clustering in the wake and changing the angle of attack requires changing the whole grid to high resolution in the new wake so I want to rotate the airfoil to a certain angle and keep the C topology. Thanks! Last edited by Sigi; January 24, 2023 at 18:41. |
January 25, 2023, 05:27 |
bigfoot
Rep Power: 17 |
No, you'll have to do this in your meshing tool
January 25, 2023, 21:36 |
Pedro Gomes
Rep Power: 13 |
You can scale, rotate, or translate su2 meshes using SU2_DEF.
For a 45-degree rotation around the z-axis the settings look something like this: DV_KIND= ROTATE_GRID DV_PARAM= (0, 0, 0, 0, 0, 1) % x0 y0 z0 x1 y1 z1 DV_VALUE= 45 |
boundary condition, mesh, rotating body, rotating boundary, su2 |
How to obtain coefficient of lift and drag of airfoil at specified angle of attack | chandra shekhar pant | OpenFOAM Running, Solving & CFD | 0 | September 1, 2021 03:03 |
High drag for airfoil compared to XFOIL and wind tunnel data | Ry10 | SU2 | 15 | October 30, 2016 17:27 |
[OpenFOAM] Plot Angle of Attack Next to Transient Pitching Airfoil | dancfd | ParaView | 6 | October 24, 2013 00:37 |
Effective angle of attack rotating blade | ebah6 | FLUENT | 0 | March 7, 2013 15:04 |
Grid types and change of angle of attack | cpinz | Main CFD Forum | 6 | October 10, 2011 11:56 |
