Questions about non-dimensionalization in cfg document |
March 1, 2023, 04:14 |
Zhang
Rep Power: 3 |
New guys in SU2.
I set totai iterations 10000. When I choose REF_DIMENSIONALIZATION= DIMENSIONAL, the calculaion stops at 4500. When I choose REF_DIMENSIONALIZATION= FREESTREAM_VEL_EQ_ONE, the calculation finished. I wonder what reason for this thing and the specific meanings of FREESTREAM_PRESS_EQ_ONE, FREESTREAM_VEL_EQ_MACH, FREESTREAM_VEL_EQ_ONE. |
March 1, 2023, 07:30 |
PENG YAN
Rep Power: 4 |
Go SU2 homepage for reference:
https://su2code.github.io/docs_v7/Ph...nsionalization. The reason that your simulation stops in advance may be that the RMS-DENSITY is lower than the convergence criterion. The value of RMS-DENSITY is differnent when you choose different non-denationalization reference. |
March 1, 2023, 22:38 |
Zhang
Rep Power: 3 |
Thanks for reminding the references. After the simulation stops, it reports "Error in "void CSysSolve::ModGramSchmidt(int, std::vector<std::vector<double> >&, std::vector<CSysVector>&)". I woder how can I slove this problem. By reducing the Min value of the residual or something else?
March 2, 2023, 02:23 |
PENG YAN
Rep Power: 4 |
It is recommended to share your config and mesh file here.
March 2, 2023, 03:10 |
Zhang
Rep Power: 3 |
% ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------%
% % Physical governing equations (EULER, NAVIER_STOKES, % WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY, % POISSON_EQUATION) PHYSICAL_PROBLEM= NAVIER_STOKES % % Specify turbulence model (NONE, SA, SA_NEG, SST, SA_E, SA_COMP, SA_E_COMP) KIND_TURB_MODEL= SST % % Mathematical problem (DIRECT, CONTINUOUS_ADJOINT, DISCRETE_ADJOINT) MATH_PROBLEM= DIRECT % % Regime type (COMPRESSIBLE, INCOMPRESSIBLE) REGIME_TYPE= COMPRESSIBLE % % Axisymmetric simulation, only compressible flows (NO, YES) AXISYMMETRIC= NO % % Restart solution (NO, YES) RESTART_SOL= NO % % Discard the data storaged in the solution and geometry files % e.g. AOA, dCL/dAoA, dCD/dCL, iter, etc. % Note that AoA in the solution and geometry files is critical % to aero design using AoA as a variable. (NO, YES) DISCARD_INFILES= NO % % System of measurements (SI, US) % International system of units (SI): ( meters, kilograms, Kelvins, % Newtons = kg m/s^2, Pascals = N/m^2, % Density = kg/m^3, Speed = m/s, % Equiv. Area = m^2 ) % United States customary units (US): ( inches, slug, Rankines, lbf = slug ft/s^2, % psf = lbf/ft^2, Density = slug/ft^3, % Speed = ft/s, Equiv. Area = ft^2 ) SYSTEM_MEASUREMENTS= SI % % ----------------------------------- END ------------------------------------ % -------------------- COMPRESSIBLE FREE-STREAM DEFINITION --------------------% % % Mach number (non-dimensional, based on the free-stream values) the only parameter of the computation!!! MACH_NUMBER= 4 % % Angle of attack (degrees, only for compressible flows) AOA= 0 % % Side-slip angle (degrees, only for compressible flows) SIDESLIP_ANGLE= 0.0 % % Init option to choose between Reynolds (default) or thermodynamics quantities % for initializing the solution (REYNOLDS, TD_CONDITIONS) INIT_OPTION= REYNOLDS % % Free-stream option to choose between density and temperature (default) for % initializing the solution (TEMPERATURE_FS, DENSITY_FS) FREESTREAM_OPTION= DENSITY_FS % % Free-stream pressure (101325.0 N/m^2, 2116.216 psf by default) %FREESTREAM_PRESSURE= 2549 % % Free-stream temperature (288.15 K, 518.67 R by default) %FREESTREAM_TEMPERATURE= 221.55 % % Reynolds number (non-dimensional, based on the free-stream values) REYNOLDS_NUMBER= 5.11E+6 % % Reynolds length (1 m, 1 inch by default) REYNOLDS_LENGTH= 1.0 % % Free-stream density (1.2886 Kg/m^3, 0.0025 slug/ft^3 by default) FREESTREAM_DENSITY= 0.04 % % Free-stream velocity (1.0 m/s, 1.0 ft/s by default) FREESTREAM_VELOCITY= ( 1790.33, 0.00, 0.00 ) % % Free-stream viscosity (1.853E-5 N s/m^2, 3.87E-7 lbf s/ft^2 by default) FREESTREAM_VISCOSITY= 1.4E-5 % % Compressible flow non-dimensionalization (DIMENSIONAL, FREESTREAM_PRESS_EQ_ONE, % FREESTREAM_VEL_EQ_MACH, FREESTREAM_VEL_EQ_ONE) REF_DIMENSIONALIZATION= DIMENSIONAL % % ----------------------------------- END -------------------------------------% % ---------------------- REFERENCE VALUE DEFINITION ---------------------------% % % Reference origin for moment computation (m or in) REF_ORIGIN_MOMENT_X = 0.25 REF_ORIGIN_MOMENT_Y = 0.00 REF_ORIGIN_MOMENT_Z = 0.00 % % Reference length for moment non-dimensional coefficients (m or in) REF_LENGTH= 1.0 % % Reference area for non-dimensional force coefficients (0 implies automatic % calculation) (m^2 or in^2) REF_AREA= 1.0 % % Aircraft semi-span (0 implies automatic calculation) (m or in) SEMI_SPAN= 0.0 % % ----------------------------------- END -------------------------------------% % ---- IDEAL GAS, POLYTROPIC, VAN DER WAALS AND PENG ROBINSON CONSTANTS -------% % % Fluid model (STANDARD_AIR, IDEAL_GAS, VW_GAS, PR_GAS, % CONSTANT_DENSITY, INC_IDEAL_GAS) FLUID_MODEL= IDEAL_GAS % % Ratio of specific heats (1.4 default and the value is hardcoded % for the model STANDARD_AIR, compressible only) GAMMA_VALUE= 1.4 % % Specific gas constant (287.058 J/kg*K default and this value is hardcoded % for the model STANDARD_AIR, compressible only) GAS_CONSTANT= 287.058 % % Critical Temperature (131.00 K by default) CRITICAL_TEMPERATURE= 131.00 % % Critical Pressure (3588550.0 N/m^2 by default) CRITICAL_PRESSURE= 3588550.0 % % Acentri factor (0.035 (air)) ACENTRIC_FACTOR= 0.035 % % Specific heat at constant pressure, Cp (1004.703 J/kg*K (air)). % Incompressible fluids with energy eqn. only (CONSTANT_DENSITY, INC_IDEAL_GAS). SPECIFIC_HEAT_CP= 1004.703 % % Molecular weight for an incompressible ideal gas (28.96 g/mol (air) default) % Incompressible fluids with energy eqn. only (CONSTANT_DENSITY, INC_IDEAL_GAS). MOLECULAR_WEIGHT= 28.96 % % Thermal expansion coefficient (0.00347 K^-1 (air)) % Used with Boussinesq approx. (incompressible, BOUSSINESQ density model only) THERMAL_EXPANSION_COEFF= 0.00347 % % ----------------------------------- END -------------------------------------% % --------------------------- VISCOSITY MODEL ---------------------------------% % % Viscosity model (SUTHERLAND, CONSTANT_VISCOSITY). VISCOSITY_MODEL= SUTHERLAND % % Molecular Viscosity that would be constant (1.716E-5 by default) MU_CONSTANT= 1.716E-5 % % Sutherland Viscosity Ref (1.716E-5 default value for AIR SI) MU_REF= 1.716E-5 % % Sutherland Temperature Ref (273.15 K default value for AIR SI) MU_T_REF= 273.15 % % Sutherland constant (110.4 default value for AIR SI) SUTHERLAND_CONSTANT= 110.4 % % ----------------------------------- END -------------------------------------% % --------------------------- THERMAL CONDUCTIVITY MODEL ----------------------% % % Conductivity model (CONSTANT_CONDUCTIVITY, CONSTANT_PRANDTL). CONDUCTIVITY_MODEL= CONSTANT_PRANDTL % % Molecular Thermal Conductivity that would be constant (0.0257 by default) KT_CONSTANT= 0.0257 % % Laminar Prandtl number (0.72 (air), only for CONSTANT_PRANDTL) PRANDTL_LAM= 0.72 % % Turbulent Prandtl number (0.9 (air), only for CONSTANT_PRANDTL) PRANDTL_TURB= 0.90 % % ----------------------------------- END -------------------------------------% % START : body and surface relative % ----------------------- BODY FORCE DEFINITION -------------------------------% % % Apply a body force as a source term (NO, YES) BODY_FORCE= NO % % Vector of body force values (BodyForce_X, BodyForce_Y, BodyForce_Z) BODY_FORCE_VECTOR= ( 0.0, 0.0, 0.0 ) % % ----------------------------------- END -------------------------------------% % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % % Euler wall boundary marker(s) (NONE = no marker) MARKER_EULER= ( NONE ) % % Navier-Stokes (no-slip), constant heat flux wall marker(s) (NONE = no marker) % Format: ( marker name, constant heat flux (J/m^2), ... ) MARKER_HEATFLUX= ( WALL, 0.0, WALL2, 0.0 WALL3, 0.0 WALL4, 0.0 WALL5, 0.0) % % Navier-Stokes (no-slip), isothermal wall marker(s) (NONE = no marker) % Format: ( marker name, constant wall temperature (K), ... ) MARKER_ISOTHERMAL= ( NONE ) % % Far-field boundary marker(s) (NONE = no marker) MARKER_FAR= ( FAR ) % % Symmetry boundary marker(s) (NONE = no marker) MARKER_SYM= ( SYS, SYS2 ) % % Internal boundary marker(s) e.g. no boundary condition (NONE = no marker) MARKER_INTERNAL= ( NONE ) % % Near-Field boundary marker(s) (NONE = no marker) MARKER_NEARFIELD= ( NONE ) % % Zone interface boundary marker(s) (NONE = no marker) MARKER_INTERFACE= ( NONE ) % % Inlet boundary type (TOTAL_CONDITIONS, MASS_FLOW) INLET_TYPE= TOTAL_CONDITIONS % % Read inlet profile from a file (YES, NO) default: NO SPECIFIED_INLET_PROFILE= NO % % File specifying inlet profile % INLET_FILENAME= inlet.dat % % Inlet boundary marker(s) with the following formats (NONE = no marker) % Total Conditions: (inlet marker, total temp, total pressure, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. % Mass Flow: (inlet marker, density, velocity magnitude, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. % Incompressible: (inlet marker, temperature, velocity magnitude, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. MARKER_INLET= ( NONE ) % % Outlet boundary marker(s) (NONE = no marker) % Format: ( outlet marker, back pressure (static), ... ) MARKER_OUTLET= ( OUT, 2000, FAROUT, 2000 ) % % Actuator disk boundary type (VARIABLES_JUMP, BC_THRUST, % DRAG_MINUS_THRUST) % ACTDISK_TYPE= VARIABLES_JUMP % % Actuator disk boundary marker(s) with the following formats (NONE = no marker) % Variables Jump: ( inlet face marker, outlet face marker, % Takeoff pressure jump (psf), Takeoff temperature jump (R), Takeoff rev/min, % Cruise pressure jump (psf), Cruise temperature jump (R), Cruise rev/min ) % BC Thrust: ( inlet face marker, outlet face marker, % Takeoff BC thrust (lbs), 0.0, Takeoff rev/min, % Cruise BC thrust (lbs), 0.0, Cruise rev/min ) % Drag-Thrust: ( inlet face marker, outlet face marker, % Takeoff Drag-Thrust (lbs), 0.0, Takeoff rev/min, % Cruise Drag-Thrust (lbs), 0.0, Cruise rev/min ) MARKER_ACTDISK= ( NONE ) % % Supersonic inlet boundary marker(s) (NONE = no marker) % Format: (inlet marker, temperature, static pressure, velocity_x, % velocity_y, velocity_z, ... ), i.e. primitive variables specified. MARKER_SUPERSONIC_INLET= ( NONE ) % % Supersonic outlet boundary marker(s) (NONE = no marker) MARKER_SUPERSONIC_OUTLET= ( NONE ) % % Periodic boundary marker(s) (NONE = no marker) % Format: ( periodic marker, donor marker, rotation_center_x, rotation_center_y, % rotation_center_z, rotation_angle_x-axis, rotation_angle_y-axis, % rotation_angle_z-axis, translation_x, translation_y, translation_z, ... ) MARKER_PERIODIC= ( NONE ) % ----------------------------------- END -------------------------------------% % ------------------------ SURFACES IDENTIFICATION ----------------------------% % % Marker(s) of the surface in the surface flow solution file MARKER_PLOTTING = ( WALL, WALL2, WALL3, WALL4, WALL5 ) % % Marker(s) of the surface where the non-dimensional coefficients are evaluated. MARKER_MONITORING = ( OUT ) % % Viscous wall markers for which wall functions must be applied. (NONE = no marker) % Format: ( marker name, wall function type, ... ) MARKER_WALL_FUNCTIONS= ( NONE, NO_WALL_FUNCTION ) % % Marker(s) of the surface where custom thermal BC's are defined. MARKER_PYTHON_CUSTOM = ( NONE ) % % % Marker(s) of the surface that is going to be analyzed in detail (massflow, average pressure, distortion, etc) MARKER_ANALYZE = ( OUT ) % % Method to compute the average value in MARKER_ANALYZE (AREA, MASSFLUX). MARKER_ANALYZE_AVERAGE = MASSFLUX % % ----------------------------------- END -------------------------------------% % ----------------------- GEOMETRY EVALUATION PARAMETERS ----------------------% % % Marker(s) of the surface where geometrical based function will be evaluated GEO_MARKER= ( NONE ) % % Description of the geometry to be analyzed (AIRFOIL, WING) GEO_DESCRIPTION= AIRFOIL % % Coordinate of the stations to be analyzed GEO_LOCATION_STATIONS= (0.0, 0.5, 1.0) % % Geometrical bounds (Y coordinate) for the wing geometry analysis or % fuselage evaluation (X coordinate) GEO_BOUNDS= (1.5, 3.5) % % Plot loads and Cp distributions on each airfoil section GEO_PLOT_STATIONS= NO % % Number of section cuts to make when calculating wing geometry GEO_NUMBER_STATIONS= 25 % % Geometrical evaluation mode (FUNCTION, GRADIENT) GEO_MODE= FUNCTION % % ----------------------------------- END -------------------------------------% % END : body and surface relative % START : computation and numerica method % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % % Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES) NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES % % CFL number (initial value for the adaptive CFL number) CFL_NUMBER= 2.0 % % Adaptive CFL number (NO, YES) CFL_ADAPT= NO % % Parameters of the adaptive CFL number (factor down, factor up, CFL min value, % CFL max value ) CFL_ADAPT_PARAM= ( 1.5, 0.5, 1.25, 50.0 ) % % Maximum Delta Time in local time stepping simulations MAX_DELTA_TIME= 1E6 % % Runge-Kutta alpha coefficients RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 ) % % -- OBJECTIVE_FUNCTION -- and -- OBJECTIVE_WEIGHT -- have been traslated to the end cfg option % % ----------------------------------- END -------------------------------------% % ----------- SLOPE LIMITER AND DISSIPATION SENSOR DEFINITION -----------------% % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the flow equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_FLOW= NO % % Slope limiter (NONE, VENKATAKRISHNAN, VENKATAKRISHNAN_WANG, % BARTH_JESPERSEN, VAN_ALBADA_EDGE) SLOPE_LIMITER_FLOW= VENKATAKRISHNAN % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the turbulence equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_TURB= NO % % Slope limiter (NONE, VENKATAKRISHNAN, VENKATAKRISHNAN_WANG, % BARTH_JESPERSEN, VAN_ALBADA_EDGE) SLOPE_LIMITER_TURB= VENKATAKRISHNAN % % Coefficient for the Venkat's limiter (upwind scheme). A larger values decrease % the extent of limiting, values approaching zero cause % lower-order approximation to the solution (0.05 by default) VENKAT_LIMITER_COEFF= 0.05 % % Coefficient for the adjoint sharp edges limiter (3.0 by default). % ADJ_SHARP_LIMITER_COEFF= 3.0 % % Freeze the value of the limiter after a number of iterations LIMITER_ITER= 999999 % % 1st order artificial dissipation coefficients for % the Lax–Friedrichs method ( 0.15 by default ) LAX_SENSOR_COEFF= 0.15 % % 2nd and 4th order artificial dissipation coefficients for % the JST method ( 0.5, 0.02 by default ) JST_SENSOR_COEFF= ( 0.5, 0.02 ) % % 1st order artificial dissipation coefficients for % the adjoint Lax–Friedrichs method ( 0.15 by default ) % ADJ_LAX_SENSOR_COEFF= 0.15 % % 2nd, and 4th order artificial dissipation coefficients for % the adjoint JST method ( 0.5, 0.02 by default ) % ADJ_JST_SENSOR_COEFF= ( 0.5, 0.02 ) % % ----------------------------------- END -------------------------------------% % ------------------------ LINEAR SOLVER DEFINITION ---------------------------% % % Linear solver or smoother for implicit formulations (BCGSTAB, FGMRES, SMOOTHER_JACOBI, % SMOOTHER_ILU, SMOOTHER_LUSGS, % SMOOTHER_LINELET) LINEAR_SOLVER= FGMRES % % Preconditioner of the Krylov linear solver (ILU, LU_SGS, LINELET, JACOBI) LINEAR_SOLVER_PREC= LU_SGS % % Linael solver ILU preconditioner fill-in level (0 by default) LINEAR_SOLVER_ILU_FILL_IN= 0 % % Minimum error of the linear solver for implicit formulations LINEAR_SOLVER_ERROR= 1E-6 % % Max number of iterations of the linear solver for the implicit formulation LINEAR_SOLVER_ITER= 5 % % ----------------------------------- END -------------------------------------% % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % % Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC, % TURKEL_PREC, MSW, FDS) CONV_NUM_METHOD_FLOW= ROE % % Roe Low Dissipation function for Hybrid RANS/LES simulations (FD, NTS, NTS_DUCROS) %ROE_LOW_DISSIPATION= FD % % Post-reconstruction correction for low Mach number flows (NO, YES) LOW_MACH_CORR= NO % % Roe-Turkel preconditioning for low Mach number flows (NO, YES) LOW_MACH_PREC= NO % % Entropy fix coefficient (0.0 implies no entropy fixing, 1.0 implies scalar % artificial dissipation) ENTROPY_FIX_COEFF= 0.0 % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT) TIME_DISCRE_FLOW= EULER_IMPLICIT % % Relaxation coefficient RELAXATION_FACTOR_FLOW= 0.95 % % ----------------------------------- END -------------------------------------% % -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------% % % Convective numerical method (SCALAR_UPWIND) CONV_NUM_METHOD_TURB= SCALAR_UPWIND % % Time discretization (EULER_IMPLICIT) TIME_DISCRE_TURB= EULER_IMPLICIT % % Reduction factor of the coefficient in the turbulence problem CFL_REDUCTION_TURB= 1.0 % % Relaxation coefficient RELAXATION_FACTOR_TURB= 0.95 % % ----------------------------------- END -------------------------------------% % --------------------- HEAT NUMERICAL METHOD DEFINITION ----------------------% % % Value of the thermal diffusivity THERMAL_DIFFUSIVITY= 1.0 % % ----------------------------------- END -------------------------------------% % START : convergence and i/o % --------------------------- CONVERGENCE PARAMETERS --------------------------% % % Number of total iterations EXT_ITER= 10000 % % Convergence criteria (CAUCHY, RESIDUAL) % CONV_CRITERIA= RESIDUAL % % Residual reduction (order of magnitude with respect to the initial value) RESIDUAL_REDUCTION= 6 % % Min value of the residual (log10 of the residual) RESIDUAL_MINVAL= -12 % Start convergence criteria at iteration number STARTCONV_ITER= 10 % % Number of elements to apply the criteria CAUCHY_ELEMS= 100 % % Epsilon to control the series convergence CAUCHY_EPS= 1E-15 % % Direct function to apply the convergence criteria (LIFT, DRAG, NEARFIELD_PRESS) CAUCHY_FUNC_FLOW= DRAG % % Adjoint function to apply the convergence criteria (SENS_GEOMETRY, SENS_MACH) CAUCHY_FUNC_ADJFLOW= SENS_GEOMETRY % % ----------------------------------- END -------------------------------------% ---% |
dimensionalization |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
[ICEM] Complex geometry mesh general questions | Jack B | ANSYS Meshing & Geometry | 0 | August 14, 2019 13:44 |
Modification of a cfg parameter in restart | Arad | SU2 | 3 | March 19, 2018 15:51 |
a document "non dimensionalization of the navier stokes equation" | wangqi198877 | SU2 | 25 | February 24, 2018 12:22 |
possible interview questions | atturh | Main CFD Forum | 1 | February 21, 2012 08:53 |
