March 8, 2024, 09:24 |
Can't find SU2_CFD_AD and SU2_DOT_AD
Rep Power: 2 |
Hi guys,
I'm trying to do the example on SU2 webpage called "Constrained shape design of a transonic turbulent airfoil at a cte. CL". However im unable to find the SU2_CFD_AD and SU2_DOT_AD as shown in the image. Im also attaching a screenshot of my repository where the only tools shown are those. Thank you. |
March 8, 2024, 10:28 |
Rep Power: 4 |
Hi David,
Did you compile SU2 with the option: -Denable-autodiff=true ? Best regards, Cristopher Morales Ubal |
March 26, 2024, 12:38 |
Rep Power: 2 |
Hi Christopher, thank you for your reply.
I'm not aware to have done this but I'm unable to understand how to complie it with that option. Could you explain the steps to follow what you mention? Thank you for your time and attention. |
March 27, 2024, 11:27 |
#4 | |
Rep Power: 4 |
Hi David, You can compile SU2 using these commands: ./meson.py build --reconfigure -Dwarning_level=2 -Denable-autodiff=true -Denable-directdiff=false -Dwith-mpi=enabled -Denable-cgns=true -Denable-tecio=false --prefix=/home/mech001/20215667/SU2 where --prefix=/home/mech001/20215667/SU2 is the installation directory. Best regards, Cristopher Morales Ubal |
March 27, 2024, 16:50 |
Rep Power: 2 |
Hi Cristopher, thanks for your reply.
As I'm using it in windows I've changed the / by \ for directories. If I write ./meson.py it just opens the python script but using python meson.py it seems to install something. However there is an error as it can't find the directory (see attached picture). For me this is strange as the directory is marked with double \\ instead of just one \. Do you have any clue on this? Thank you very much. |
March 27, 2024, 17:40 |
bigfoot
Rep Power: 17 |
Here is your main mistake:
Use Linux, which is a real developers platform. You can install it inside a virtual box if for some reason you still need have windows for something. There are so many things that you need to set up in windows to get this running that this is by far the easiest option for you. |
March 28, 2024, 04:52 |
Rep Power: 2 |
Thank you for your reply.
Would you recommend to use WSL 2 or to use a virtualbox? Thank you |
March 28, 2024, 08:44 |
Rep Power: 2 |
Hi Cristopher and bigfootedrockmidget,
I've already install and compiled everything except the AD build in an Ubuntu Linux system. Have you been able to use the AD build? If so, which version of SU2 did you use and which steps did you follow? Thank you. |
March 30, 2024, 08:56 |
#9 | |
Rep Power: 4 |
you can compile the AD using the latest version of SU2, be sure that you use the develop branch. if you open the terminal within the SU2 folder , you can type: git status then you will see the branch where you are. you can switch to develop using the following command: git checkout develop and then recompile again using this command line: ./meson.py build --reconfigure -Dwarning_level=2 -Denable-autodiff=true -Denable-directdiff=false -Dwith-mpi=enabled -Denable-cgns=true -Denable-tecio=false --prefix=/home/mech001/20215667/SU2 you must also download FADO and add the path of FADO in your .bashrc file. you can do it opening a terminal and type: nano .bashrc and then you should add the lines in the picture attached. best regards, Cristopher Morales Ubal |
March 30, 2024, 09:16 |
#10 |
Rep Power: 2 |
Hi Cristopher,
when typing git status there is an error saying: fatal: no es un repositorio git (ni ninguno de los directorios superiores): .git sorry it is in spanish (traduction): it is not a git repository. Any idea on this? Thank you. |
March 30, 2024, 09:18 |
#11 | |
Rep Power: 4 |
could you share an screenshot of the folder where you have installed SU2? and a screenshot of your terminal? |
March 30, 2024, 09:20 |
#12 |
Rep Power: 2 |
This would be it. Descargas means downloads.
March 30, 2024, 09:22 |
#13 |
Rep Power: 2 |
Would it be possible to make any kind of call by meets or discord?
March 30, 2024, 09:24 |
#14 |
Rep Power: 4 |
March 30, 2024, 09:29 |
#15 |
Rep Power: 2 |
The steps I've followed are this:
1. Download the 8.0.1 version from SU2 release in the tar format 2. then use command: tar xzvf SU2-8.0.1.tar.gz 3. then use cd to get inside this folder 4. then: sudo apt install git 5. then: ./meson.py build 6. then: ./ninja -C build install 7. then: nano .bashrc to include the paths 8. then source ~./bashrc to save it 9. end |
March 31, 2024, 13:08 |
#16 |
Rep Power: 2 |
Dear Cristopher, as the 8.0.1 version was not working well for me I installed version 7.0.4 which works fine.
I've installed everything and then I then tried to reconfigure for the AD build using the command you pasted (./meson.py build --reconfigure -Dwarning_level=2 -Denable-autodiff=true -Denable-directdiff=false -Dwith-mpi=enabled -Denable-cgns=true -Denable-tecio=false --prefix=/home/mech001/20215667/SU2 where --prefix=/home/mech001/20215667/SU2 is the installation directory) (see picture 1). It works fine. But then when calling ninja it gives me the following error for the mpi.h. Do you have any clue about why? In order to reconfigure something the procedure is to first define the configuration with meson and then use ninja to install the packages? Thank you for your time and help. |
April 1, 2024, 05:15 |
#17 | |
Rep Power: 4 |
it seems that you have not installed an MPI, you can follow this installation procedure: https://rantahar.github.io/introduct...mpi/setup.html In order to reconfigure something the procedure is to first define the configuration with meson and then use ninja to install the packages? Yes, you must reconfigure meson and next use ninja to compile. Best regards. Cristopher Morales |
April 1, 2024, 11:08 |
#18 |
Rep Power: 2 |
Hi Cristopher,
For the case of SU2 version 7.0.4, after compiling with ninja, comands: make and then: sudo make install are used. What does these commands do and are they necessary after each reconfiguration? Thank you. |
April 1, 2024, 13:00 |
#19 | |
Rep Power: 4 |
I think sudo make install is not needed after each reconfiguration. Best regards, Cristopher Morales Ubal |
April 1, 2024, 15:19 |
#20 |
Rep Power: 2 |
Dear Cristopher.
I've followed the steps you mentioned and try to run the example shown in: https://su2code.github.io/tutorials/...ained_RAE2822/ However, when running: shape_optimization.py -g DISCRETE_ADJOINT -o SLSQP -f turb_SA_RAE2822.cfg This is the error it says (see picture). It looks like it is unable to find the SU2_CFD_AD, however i can find it in the folder (see picture). Should this location be added to the nano .basrhc in some way? Could it be any other error? Once again, thank you for your time and help. |
cfd, su2, tools |
