INC_INLET_USENORMAL - velocity direction @ inlet |
April 5, 2024, 01:34 |
Giovanni Bettega
Rep Power: 11 |
Hello
I have to handle multiple inlets in a fluid domain I would like to inject flow along a user-defined direction for some inlets, and along a local, auto-computed direction for other inlets. The solver setting INC_INLET_USENORMAL= NO (or YES) it's what I need. Does this setting affects ALL the inlets at one time, or is it possible possibility to define a list of bool values, for assigning Y/N to the list of inlets (e.g. INC_INLET_USENORMAL= NO, YES for inlet1, and inlet2) Grazie mille Giovannni |
April 5, 2024, 02:15 |
bigfoot
At the moment INC_INLET_USENORMAL takes one single value for all inlets.If you would like to see this functionality, you could add a feature request on github (or implement it yourself). I think it is a good idea to add it.
April 5, 2024, 03:05 |
Giovanni Bettega
Rep Power: 11 |
Thank you
I expected a situation like that. Actually it's a minor, I think, change, but could be important. Tools like Ansys CFX usually give the possibility ti apply such a setting to all the user defined onlets. My answer comes from a long activity whose result is a GUI integrated environment, meshing and post included, able to handle flow simulations, using Su2 as a solver, so, in setting "inlet options" I encountered this issue (which actually Is not a true issue). Grazie mille Giovanni |
configuration file, inlet, su2 8.0.0 |
Import .csv - velocity profile - error | eSKa | CFX | 9 | April 3, 2021 13:38 |
Specify both velocity and pressure at inlet boundary | NOD | STAR-CCM+ | 4 | March 7, 2021 06:36 |
serial udf to parallel udf | radioss | Fluent UDF and Scheme Programming | 10 | January 19, 2019 08:56 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
How to define a fixed velocity for a given mass flow rate on inlet | mqasimali | FLUENT | 2 | April 12, 2013 17:24 |
