Home > Forums > General Forums > System Analysis
Venturi Suction
Old   November 23, 2021, 06:53
Default Venturi Suction
Johan
Johan111 is on a distinguished road
Good day
I am trying to use a venturi across a centrifugal pump. The pressure at suction side is about 2 bar and the discharge pressure about 6 to 7 bar. This pump supply drippers and the delivery is about 180 cub/h. I need to inject entrainment air into the suction side and try to use a venturi across the high (discharge) and low (suction) pressure sides of the pump.
I get little to no suction on the venturi. I have a throttling valve to play around with the flow through the venturi. The setup have also quite alot of bends.
Can the low suction be the pressure loss on these bends and relative low diameter pipe between the high and low pressure.
Thank you for feedback
Johan111 is offline   Reply With Quote
venturi
[TurboGrid] How to best model centrifugal pump impeller and suction domains using TurboGrid jgross ANSYS Meshing & Geometry 1 December 28, 2021 17:10
Venturi injector suction not adequate (Layman here!) k_v Main CFD Forum 0 July 24, 2020 10:11
Modeling vacuum suction through pipe in ANSYS Fluent mamoody14 FLUENT 1 February 20, 2019 14:09
VOF models on venturi scrubber simulation toda FLUENT 3 June 2, 2016 12:51
Venturi tube Simbelmynė Main CFD Forum 9 August 31, 2012 02:09
