Home > Forums > General Forums > System Analysis
Solution to investigate the flashing potential in high pressure drain line
Old   May 6, 2024, 04:15
Default Solution to investigate the flashing potential in high pressure drain line
Thomas Nguyen
tannh is on a distinguished road
Hi everyone,
I am currently investigating an operational problem with the drain line of high pressure feedwater heater in power station. It vibrated with high amplitude during operation.
This drain line is from high pressure heater working at pressure 1.8 MPa, drains to deaerator at 0.6 MPa, there are bend, T-shape welds, gate type isolation valve, control valve.
I suppose there are flashing at some point along the pipe, because the problem arise when the heater deteriorate following by the rise of drain water temperature.
I would like to be suggested how to build a model to investigate the flashing potential, specific with openFoam.
I appreciate your recomendations.
tannh is offline   Reply With Quote
[OpenFOAM] ParaView command in Foam-extend-4.1 mitu_94 ParaView 0 March 4, 2021 13:46
[OpenFOAM] Take derivative of mean velocity in paraFoam hiuluom ParaView 13 April 26, 2016 06:44
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
