Home > Forums > Visualization & Post-Processing Software > Tecplot
Calculating vortex cores of relative velocities
Like Tree1Likes
  • 1 Post By Dorit
Old   September 19, 2013, 10:19
Default Calculating vortex cores of relative velocities
Dorit is on a distinguished road
Hi, I want to use Tecplot to calculate the vortex core behind a wind turbine blade. I'm using a moving reference frame in Fluent to simulate the flow around the turbine blade. When I read the resulting case and data files into Tecplot I first convert the absolute velocities into relative velocities and then apply the new the new variables:
> Data > Alter > Specify Equations: {v_rel_x}=... {v_rel_y}=... {v_rel_z}=...
> Analyze > Field Variables: U={v_rel_x} V={v_rel_y} Z={v_rel_z}
But when I calculate the vortex core Tecplot always calculates it using the absolute velocities and not the relative ones that I specified. Does anyone have an idea of how I can use the velocities that I specified??
Thank you,
Dorit
863864536@qq.com likes this.
Dorit is offline   Reply With Quote
Old   December 17, 2015, 05:23
Smile vortex core
浅笑221
863864536@qq.com is on a distinguished road
hello,i have found the same problem that the vortex core is invariant even we change the filed variable,have you found a method?please tell me,thank you!
863864536@qq.com is offline   Reply With Quote
post procesing, relative velocity, tecplot, vortex
how to get relative velocities in a rotating frame of reference? alkochevsky OpenFOAM Post-Processing 14 May 31, 2017 06:05
Presenation of vortex strength and velocity concept? fruitkiwi Main CFD Forum 0 September 26, 2012 22:08
Vortex Lattice Method: Calculating lift using circulation from vortex ring elements black&gold Main CFD Forum 11 June 26, 2011 23:51
UDF for vortex cores Grace Fluent UDF and Scheme Programming 0 March 18, 2010 05:19
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
