How to deal with the data file for unsteady problem with Tecplot?
In other words, I mean that how to deal with the time step in the data file so that tecplot can read it. Thanks! |
I'm not sure if I understood you right. What I do if i want to load the many timeshots is load multiple files using the add to the current data set option.I write each timeshot file as filename_time.dat.
Hope this helps |
Hi, Harish
Your way is to build each data file for each timeshot. I ever have thought over this way. But I think that this can produce too many data files. So I want to know whether there are some other more concise ways to deal with the problem. |
I do it the same way Harish does it, then use a macro to create an animation.
If you have tecplot 360 you can possible write a macro in python to handle the opening of all those files and producing the animation.
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
TECPLOT file data format Plz Explain | whats_in_a_name | FLUENT | 1 | February 21, 2007 08:50 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
