Home > Forums > Visualization & Post-Processing Software > Tecplot
A problme to write data file with Tecplot
Old   October 29, 2007, 08:42
Default A problme to write data file with Tecplot
Kai Yan
How to deal with the data file for unsteady problem with Tecplot?
In other words, I mean that how to deal with the time step in the data file so that tecplot can read it.
Thanks!
Old   October 29, 2007, 10:41
Default Re: A problme to write data file with Tecplot
Harish
I'm not sure if I understood you right. What I do if i want to load the many timeshots is load multiple files using the add to the current data set option.I write each timeshot file as filename_time.dat.
Hope this helps
Old   October 29, 2007, 21:45
yka8150
Hi, Harish
Your way is to build each data file for each timeshot. I ever have thought over this way. But I think that this can produce too many data files.
So I want to know whether there are some other more concise ways to deal with the problem.
Old   October 30, 2007, 07:53
ag
I do it the same way Harish does it, then use a macro to create an animation.
Old   October 30, 2007, 13:44
Harish
If you have tecplot 360 you can possible write a macro in python to handle the opening of all those files and producing the animation.
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
TECPLOT file data format Plz Explain whats_in_a_name FLUENT 1 February 21, 2007 08:50
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
