Home > Forums > Visualization & Post-Processing Software > Tecplot
Matlab to Tecplot
Old   January 18, 2015, 17:42
Default Matlab to Tecplot
amine
lbmagis is on a distinguished road
Hello friends,
the problem is: there is a 2D domain (square for example) which i need to simule the temperature (heat transfer) through it using a matlab code.
well when we run the code (the data updated every time unit"iteration"), at the end we will obtain a contour of Temperature.
I would like to know the way i could export this data (temperature contour) from matlab to tecplot in order to make a post-processing using the mat2tecplot code.
i tried it many times but it didnt work.
Can anyone give me the code to do that???Thank you
lbmagis is offline   Reply With Quote
Old   January 22, 2015, 18:57
Default Check out the resources on writing data from MATLAB
Durrell Rittenberg
Durrell4 is on a distinguished road
Send a message via MSN to Durrell4 Send a message via Yahoo to Durrell4 Send a message via Skype™ to Durrell4
Hi lbmagis,
We have some example code for writing data from MATLAB to Tecplot *.plt here. (http://www.tecplot.com/blog/2014/07/...s-matlab-data/)
I am not sure that this will help with the formatting the data from an iteration perspective. Please send me your code and I can see if I can trouble shoot it.
d.rittenberg@tecplot.com.
Durrell
Durrell4 is offline   Reply With Quote
Matlab to tecplot 9.0 lbmagis Main CFD Forum 0 July 5, 2012 18:34
how to import matlab file(lid-driven cavity 2d flow) in tecplot 9.0.0-9 lbmagis Tecplot 0 June 30, 2012 10:21
lid-cavity :No Bmp loader or Matlab loader on my Tecplot 9.0.0-9 lbmagis Tecplot 0 June 29, 2012 19:18
I created a tecplot binary file... Lupocci Tecplot 6 June 27, 2012 19:56
TECPLOT file data format Plz Explain whats_in_a_name FLUENT 1 February 21, 2007 08:50
